battery_compatibility:can-bus_bms-cable [2017-12-13 16:31] – [1. Introduction] mvaderbattery_compatibility:can-bus_bms-cable [2026-10-10 08:37] (current) – [1. Selecting the right cable] guy_stewart
 ====== VE.Can to CAN-bus BMS cables manual ====== ====== VE.Can to CAN-bus BMS cables manual ======
-===== 1. Introduction ===== +Use these [[https://www.victronenergy.com/cables/ve-can-to-can-bus-bms|VE.Can to CAN-bus cables]] to connect a CAN-bus enabled battery to a [[https://www.victronenergy.com/live/venus-os:start|GX device]].
-Use this cable to connect a CAN-bus enabled battery to a Victron system.+
-The side labeled 'CAN-bus BMS' plugs into the battery. The other side, labeled 'VE.Can' must be plugged into the VE.Can port of the Venus-device.
-There are two types, each with different pinning. Some brands of batteries require a Type A. Other brands require the Type B cable.+===== 1. Selecting the right cable =====
-Type A compatible batteries:+=== ASS030710118 - VE.Can to CAN-bus BMS type A Cable 1.8m ===
   * BYD B-Box   * BYD B-Box
 +  * Discover HELIOS ESS (direct to COM2, without LYNK II)
 +  * Hubble Lithium via CloudLink (incl. AM-10+/Blade internal CloudLink)
 +  * Pylontech US2000C/US3000C/UP5000/Force-L
-Type B compatible batteries:+=== ASS030720118 - VE.Can to CAN-bus BMS type B Cable 1.8m ===
-  * LG Chem Resu +  * AXIstorage 7S/9S
-  * AXIstorage+
   * BMZ   * BMZ
-  * Pylontech+  * BSLBATT Lithium battery
 +  * LG Chem Resu
 +  * Pylontech US2000/US3000/UP2500
 +  * Solar MD BMS EX
 +  * Freedom Won eTower
-===== 2. Pin-out =====+=== ASS030064950 RJ45 UTP Cable (Standard Ethernet) ===
 +  * Bluenova Energy Storage
 +  * Cegasa eBick
 +  * Freedom Won LiTE
 +  * MG Energy Systems
 +=== Custom (See Battery Documentation) ===
 +  * Exide
 +  * SolarMD Logger V2
 +===== 2. Installation =====
 +The side labeled 'CAN-bus BMS' plugs into the battery. The other side, labeled 'VE.Can' must be plugged into either the VE.Can port of the GX device, or the BMS-Can port.
 +Both port types (VE.Can and BMS-Can) on a GX Device can be configured for use with a CAN-bus BMS connected third party battery.
 +For configuration, see the manual specific to the brand of battery you are using.
 +===== 3. Pin-out =====
 In some cases it might be needed to make the cable at the location. Find below the pin-outs. Make sure to very carefully test the cable after crimping it. Self-made cables are very often the causes of very hard to diagnose problems. In some cases it might be needed to make the cable at the location. Find below the pin-outs. Make sure to very carefully test the cable after crimping it. Self-made cables are very often the causes of very hard to diagnose problems.
-==== 2.1 Type A ====+==== 3.1 Type A ====
 ^ Function ^ Victron VE.Can side ^ Battery side ^ ^ Function ^ Victron VE.Can side ^ Battery side ^
 | GND      | Pin 3        | Pin 6       | | GND      | Pin 3        | Pin 6       |
Line 29: Line 51:
 | CAN-H    | Pin 7        | Pin 4       | | CAN-H    | Pin 7        | Pin 4       |
-==== 2.2 Type B ====+==== 3.2 Type B ====
Line 36: Line 58:
-===== DISQUS ===== +
-~~DISQUS~~+
battery_compatibility/can-bus_bms-cable.1513182679.txt.gz · Last modified: by mvader
