battery_compatibility:can-bus_bms-cable [2019-08-15 12:46] – replace venus-device with GX device guy_stewart | battery_compatibility:can-bus_bms-cable [2023-12-14 07:05] (current) – [1. Selecting the right cable] warwickchapman | ||
Line 9: | Line 9: | ||
* BYD B-Box | * BYD B-Box | ||
+ | * Pylontech US2000C/ | ||
=== ASS030720018 - VE.Can to CAN-bus BMS type B Cable 1.8m === | === ASS030720018 - VE.Can to CAN-bus BMS type B Cable 1.8m === | ||
- | | + | * AXIstorage |
* BMZ | * BMZ | ||
- | * Pylontech | + | |
+ | * Hubble Lithium | ||
+ | * LG Chem Resu | ||
+ | * Solar MD BMS EX | ||
+ | === ASS030064950 RJ45 UTP Cable (Standard Ethernet) === | ||
+ | * Bluenova Energy Storage | ||
+ | * Cegasa eBick | ||
+ | * Freedom Won | ||
+ | * MG Energy Systems | ||
+ | === Custom (See Battery Documentation) === | ||
+ | * Exide | ||
+ | * SolarMD Logger V2 | ||
===== 2. Installation ===== | ===== 2. Installation ===== | ||
- | The side labeled ' | + | The side labeled ' |
+ | Both port types (VE.Can and BMS-Can) on a GX Device can be configured for use with a CAN-bus BMS connected third party battery. | ||
For configuration, | For configuration, | ||
Line 41: | Line 57: | ||
- | ~~DISQUS~~ | ||
battery_compatibility/can-bus_bms-cable.txt · Last modified: 2023-12-14 07:05 by warwickchapman
