battery_compatibility:can-bus_bms-cable [2019-08-15 12:46] – replace venus-device with GX device guy_stewart | battery_compatibility:can-bus_bms-cable [2022-07-20 19:08] – [1. Selecting the right cable] add UP5000 (confirmed and requested by Alex) stefanie | ||
Line 9: | Line 9: | ||
* BYD B-Box | * BYD B-Box | ||
+ | * Pylontech US2000C/ | ||
=== ASS030720018 - VE.Can to CAN-bus BMS type B Cable 1.8m === | === ASS030720018 - VE.Can to CAN-bus BMS type B Cable 1.8m === | ||
Line 15: | Line 16: | ||
* AXIstorage | * AXIstorage | ||
* BMZ | * BMZ | ||
- | * Pylontech | + | * Pylontech |
+ | * Solar MD BMS EX | ||
===== 2. Installation ===== | ===== 2. Installation ===== | ||
- | The side labeled ' | + | The side labeled ' |
+ | Both port types (VE.Can and BMS-Can) on a GX Device can be configured for use with a CAN-bus BMS connected third party battery. | ||
For configuration, | For configuration, | ||
Line 41: | Line 45: | ||
- | ~~DISQUS~~ | ||
battery_compatibility/can-bus_bms-cable.txt · Last modified: 2023-12-14 07:05 by warwickchapman
