battery_compatibility:can-bus_bms-cable [2019-01-22 10:16] – external edit 127.0.0.1 | battery_compatibility:can-bus_bms-cable [2019-08-15 12:46] – replace venus-device with GX device guy_stewart | ||
====== VE.Can to CAN-bus BMS cables manual ====== | ====== VE.Can to CAN-bus BMS cables manual ====== | ||
- | Use these [[https:// | + | Use these [[https:// |
Line 19: | Line 19: | ||
===== 2. Installation ===== | ===== 2. Installation ===== | ||
- | The side labeled ' | + | The side labeled ' |
For configuration, | For configuration, |
battery_compatibility/can-bus_bms-cable.txt · Last modified: 2023-12-14 07:05 by warwickchapman
