battery_compatibility:can-bus_bms-cable [2018-02-06 16:54] – [1. Introduction] mvader | battery_compatibility:can-bus_bms-cable [2019-01-22 10:16] – external edit 127.0.0.1 | ||
====== VE.Can to CAN-bus BMS cables manual ====== | ====== VE.Can to CAN-bus BMS cables manual ====== | ||
- | Use these cables to connect a CAN-bus enabled battery to a Victron system. | + | Use these [[https:// |
===== 1. Selecting the right cable ===== | ===== 1. Selecting the right cable ===== | ||
Line 38: | Line 39: | ||
| CAN-L | | CAN-L | ||
| CAN-H | | CAN-H | ||
battery_compatibility/can-bus_bms-cable.txt · Last modified: 2023-12-14 07:05 by warwickchapman
