battery_compatibility:can-bus_bms-cable [2017-12-13 17:31] – [1. Introduction] mvader | battery_compatibility:can-bus_bms-cable [2019-10-28 10:48] – [DISQUS] mvader | ||
====== VE.Can to CAN-bus BMS cables manual ====== | ====== VE.Can to CAN-bus BMS cables manual ====== | ||
- | ===== 1. Introduction ===== | + | Use these [[https:// |
- | Use this cable to connect a CAN-bus enabled battery to a Victron system. | + | |
- | The side labeled ' | ||
- | There are two types, each with different pinning. Some brands of batteries require a Type A. Other brands require | + | ===== 1. Selecting |
- | Type A compatible batteries: | + | === ASS030710018 - VE.Can to CAN-bus BMS type A Cable 1.8m === |
* BYD B-Box | * BYD B-Box | ||
- | Type B compatible batteries: | + | === ASS030720018 - VE.Can to CAN-bus BMS type B Cable 1.8m === |
* LG Chem Resu | * LG Chem Resu | ||
Line 19: | Line 17: | ||
* Pylontech | * Pylontech | ||
- | ===== 2. Pin-out ===== | + | ===== 2. Installation ===== |
+ | The side labeled ' | ||
+ | For configuration, | ||
+ | ===== 3. Pin-out ===== | ||
In some cases it might be needed to make the cable at the location. Find below the pin-outs. Make sure to very carefully test the cable after crimping it. Self-made cables are very often the causes of very hard to diagnose problems. | In some cases it might be needed to make the cable at the location. Find below the pin-outs. Make sure to very carefully test the cable after crimping it. Self-made cables are very often the causes of very hard to diagnose problems. | ||
- | ==== 2.1 Type A ==== | + | ==== 3.1 Type A ==== |
^ Function ^ Victron VE.Can side ^ Battery side ^ | ^ Function ^ Victron VE.Can side ^ Battery side ^ | ||
| GND | Pin 3 | Pin 6 | | | GND | Pin 3 | Pin 6 | | ||
Line 29: | Line 33: | ||
| CAN-H | | CAN-H | ||
- | ==== 2.2 Type B ==== | + | ==== 3.2 Type B ==== |
Line 36: | Line 40: | ||
battery_compatibility/can-bus_bms-cable.txt · Last modified: 2023-12-14 07:05 by warwickchapman
