battery_compatibility:can-bus_bms-cable [2018-02-06 16:54] – [1. Introduction] mvader | battery_compatibility:can-bus_bms-cable [2022-07-20 19:08] – [1. Selecting the right cable] add UP5000 (confirmed and requested by Alex) stefanie | ||
====== VE.Can to CAN-bus BMS cables manual ====== | ====== VE.Can to CAN-bus BMS cables manual ====== | ||
- | Use these cables to connect a CAN-bus enabled battery to a Victron system. | + | Use these [[https:// |
===== 1. Selecting the right cable ===== | ===== 1. Selecting the right cable ===== | ||
Line 8: | Line 9: | ||
* BYD B-Box | * BYD B-Box | ||
+ | * Pylontech US2000C/ | ||
=== ASS030720018 - VE.Can to CAN-bus BMS type B Cable 1.8m === | === ASS030720018 - VE.Can to CAN-bus BMS type B Cable 1.8m === | ||
Line 14: | Line 16: | ||
* AXIstorage | * AXIstorage | ||
* BMZ | * BMZ | ||
- | * Pylontech | + | * Pylontech |
+ | * Solar MD BMS EX | ||
===== 2. Installation ===== | ===== 2. Installation ===== | ||
- | The side labeled ' | + | The side labeled ' |
+ | Both port types (VE.Can and BMS-Can) on a GX Device can be configured for use with a CAN-bus BMS connected third party battery. | ||
For configuration, | For configuration, | ||
Line 39: | Line 44: | ||
| CAN-H | | CAN-H | ||
battery_compatibility/can-bus_bms-cable.txt · Last modified: 2024-05-08 12:47 by warwickchapman
