battery_compatibility:byd_b-box [2019-02-18 14:08] – guy_stewart | battery_compatibility:byd_b-box [2019-03-16 06:38] – guy_stewart | ||
Line 29: | Line 29: | ||
- | === 1.2 A Venus-device is required, | + | === 1.2 A Venus-device is required, |
- | It is essential to use the CAN-bus connection of the CCGX or VGX with the BYD batteries for the keep-alive signal, communication of charge and discharge limits, error codes and state of charge. | + | It is essential to use the CAN-bus connection of a [[venus-os: |
- | When used with B-Box batteries, the minimum required firmware version for the [[https:// | + | When used with B-Box batteries, the minimum required firmware version for the [[venus-os:start|Venus-device]] is v2.15. It is highly recommended to use the latest firmware version on all connected devices, including CCGX/VGX, Inverter/ |
Line 55: | Line 55: | ||
The MPPT requires connection to the [[venus-os: | The MPPT requires connection to the [[venus-os: |
