battery_compatibility:byd_b-box [2019-01-22 10:16] – external edit 127.0.0.1 | battery_compatibility:byd_b-box [2019-02-12 21:33] – guystewart | ||
Line 144: | Line 144: | ||
Minimum discharge SOC for 1 single Battery Box L 3.5 is 12%; for 2 or more (7kWh+) it can be 10%. | Minimum discharge SOC for 1 single Battery Box L 3.5 is 12%; for 2 or more (7kWh+) it can be 10%. | ||
- | Up to 5 L modules can be installed per L series BCU; 6 or more will require additional BCU. | + | Up to 4 L modules can be installed per L series BCU; 5 or more will require additional BCU. |
Line 361: | Line 361: | ||
This limitation also applies to charge currents as well as loads. However it is more common to have low powered loads for long periods of time than low charge currents. | This limitation also applies to charge currents as well as loads. However it is more common to have low powered loads for long periods of time than low charge currents. | ||
- | The reported State of Charge will self correct when the battery is 100% full or near 10% empty, and this can appear as sudden jumps in the VRM from very little load or charge. | + | The reported State of Charge will self correct when it reaches |
This has no impact on actual usable capacity of battery, only on the how it is reported to the user and other systems (such as alarms or triggers). | This has no impact on actual usable capacity of battery, only on the how it is reported to the user and other systems (such as alarms or triggers). | ||
Line 407: | Line 407: | ||
===== 11. Further Information ===== | ===== 11. Further Information ===== | ||
