battery_compatibility:bsl
battery_compatibility:bsl [2021-04-14 13:49] – initial publication guystewart | battery_compatibility:bsl [2024-02-21 14:22] (current) – [5.1 Victron MPPT charger settings] warwickchapman | ||
- | ====== Victron & BSL ====== | + | ====== Victron & BSLBATT Lithium batteries |
- | ===== Product & System compatibility ===== | + | [[https:// |
- | The integration with Victron and BSL batteries has been tested, complies with Victron' | + | =====1. Product & System compatibility ===== |
- | === Offgrid, Backup and Energy Storage Systems (ESS) === | + | The integration with Victron and BSLBATT batteries has been tested, complies with Victron' |
- | Victron + BSL can be used for the following system types: | + | |
+ | ===1.1 Offgrid, Backup and Energy Storage Systems (ESS) === | ||
+ | Victron + BSLBATT | ||
* Energy Storage Systems - Self Consumption ([[ess: | * Energy Storage Systems - Self Consumption ([[ess: | ||
Line 14: | Line 17: | ||
__Special note for Off-Grid systems__ | __Special note for Off-Grid systems__ | ||
- | For Off-grid systems, its strongly recommend to make sure there is a minimum of DC-Coupled PV (= MPPT Solar Charger) in the system. Ie. not only AC-Coupled PV. Also, minimum battery configuration, | + | For Off-grid systems, its strongly recommend to make sure there is a minimum of a single |
- | === A GX device is required, eg Cerbo GX, etc === | + | === 1.2 A GX device is required, eg Cerbo GX, etc === |
- | It is essential to use the BMS-Can (or CAN-bus) connection of a [[venus-os: | + | It is essential to use the BMS-Can (or CAN-bus) connection of a [[venus-os: |
The minimum supported firmware version for the [[venus-os: | The minimum supported firmware version for the [[venus-os: | ||
- | === All 48V Multis, MultiPlusses, | + | === 1.3 All 48V Multis, MultiPlusses, |
Line 30: | Line 33: | ||
In grid connected systems, advanced control functions are configurable in the ESS settings on the [[venus-os: | In grid connected systems, advanced control functions are configurable in the ESS settings on the [[venus-os: | ||
- | In off-grid systems, the control functions of the BSL Battery Management System (BMS) are built into the latest version of the [[venus-os: | + | In off-grid systems, the control functions of the BSLBATT |
- | === Solar Charger compatibility === | + | === 1.4 Solar Charger compatibility === |
All 48V BlueSolar and SmartSolar VE.Direct MPPT Chargers are compatible (*). | All 48V BlueSolar and SmartSolar VE.Direct MPPT Chargers are compatible (*). | ||
Line 42: | Line 45: | ||
(*) with exception of the models “BlueSolar MPPT 150/70 CAN-bus” and “BlueSolar MPPT 150/85 CAN-bus” which are end-of-life since 2019. Legacy systems, historically installed with this configuration using the allow to charge contacts may be possible, speak to your dealer for more information. | (*) with exception of the models “BlueSolar MPPT 150/70 CAN-bus” and “BlueSolar MPPT 150/85 CAN-bus” which are end-of-life since 2019. Legacy systems, historically installed with this configuration using the allow to charge contacts may be possible, speak to your dealer for more information. | ||
+ | It should be noted that one should always connect the battery before connecting the solar input to any MPPT. | ||
+ | The CAN-bus baud rate is 500kbis/s for communication between BSL batteries and any GX device. | ||
=== Battery compatibility === | === Battery compatibility === | ||
The following batteries are supported: | The following batteries are supported: | ||
- | ^ BSL type ^ | + | ^ BSLBATT |
| B-LFP48-100E | | B-LFP48-100E | ||
- | | B-LFP48-120E | | + | | B-LFP48-125E | |
- | | BSLBATT-5000U | | + | | B-LFP48-160E |
+ | | B-LFP48-200PW | ||
- | ===== Configuration settings ===== | ||
- | Integration instructions for Victron and BSL is described in this manual - | + | ===== 2. Minimum Battery Sizing ===== |
+ | The following information is provided by BSL, it is reproduced here for your convenience and should always be confirmed with the latest BSL manuals and specifications. | ||
+ | It should also be noted that these are the minimum requirements for the BSL battery range and that each unit can be paralleled many times over. Please consult the relevant manual on how many units can be placed in parallel. | ||
+ | The table below shows the __**minimum**__ number of battery modules required for the specified inverter/ | ||
+ | === Battery Modules Required - 5.1kWh/ | ||
+ | |Phases| | ||
+ | | Inverter/ | ||
+ | | Multiplus & Multiplus II & MP-II GX 48/ | ||
+ | | Quattro 48/ | ||
+ | | EasySolar 48/ | ||
+ | === Battery Modules Required - 6.4kWh/ | ||
+ | |Phases| | ||
+ | === Battery Modules Required - 8.2kWh/ | ||
+ | |Phases| | ||
+ | === Battery Modules Required - 10.2kWh/ | ||
+ | |Phases| | ||
+ | ===== 3. CAN-Bus wiring between battery and GX device ===== | ||
+ | In order to connect your battery to the relevant GX device, one must utilize a "Type B" cable, the Victron part number for this cable is : ASS030720018. | ||
+ | One should always terminate the CAN port on the GX device when it comes to installing BSL batteries. | ||
+ | ===== 4. Configuration settings ===== | ||
+ | === 4.1 Charger tab === | ||
+ | ^ VEConfigure Charge Parameter | ||
+ | | Battery type | Lithium | | ||
+ | | Charge curve | Fixed | ||
+ | | Absorption voltage | ||
+ | | Absorption voltage off-grid systems | ||
+ | | Float voltage (1) | 55 V | | ||
+ | | Absorption time | 1 Hr | | ||
+ | === 4.2 Inverter Settings === | ||
+ | In the Inverter tab of VEConfigure | ||
+ | ^VEConfigure Inverter Parameter | ||
+ | |DC input low shut-down | 47V| | ||
+ | |DC input low restart | ||
+ | |DC input low pre-alarm* | 51V| | ||
+ | === 4.3 ESS Settings === | ||
+ | ^ ESS Parameter ^ Settings ^ | ||
+ | |Sustain voltage. | ||
+ | |Dynamic cut-off values | set all values to 47V.| | ||
+ | |Restart offset: | ||
+ | === 4.4 All Settings === | ||
+ | Integration instructions for Victron and BSLBATT is described in this manual - | ||
+ | === 4.5 Specific manuals for various models of battery: === | ||
+ | * 5.1kWh battery- {{ : | ||
+ | * 6.4kWh battery- {{ : | ||
+ | * 7kWh battery- {{ : | ||
+ | * 8.2kWh battery- {{ : | ||
+ | * 10.2kWh battery- {{ : | ||
+ | * 15kWh battery- {{ : | ||
+ | * Powerline-5 battery- {{ : | ||
+ | ===== 5. Solar Charging ===== | ||
+ | ==== 5.1 Victron MPPT charger settings ==== | ||
+ | Victron MPPT charge characteristics are automatically configured & governed by the [[venus-os: | ||
+ | Select Battery > Preset > Smart Lithium | ||
+ | |Battery voltage | ||
+ | |Absorption voltage | ||
+ | |Float voltage | ||
+ | The MPPT should also be configured correctly in case of the GX device failing and thus not being able to throttle up or down the charging currents and voltages. | ||
+ | ===== 6. Battery configured correctly ===== | ||
+ | Here is a series of screenshots showing the result: | ||
Line 63: | Line 197: | ||
+ | ===== 7. Trouble shooting ===== | ||
+ | ==== 7.1 Battery not turning on ==== | ||
+ | If the battery does not want to turn on, there may be a variety of reasons for this including lightning strikes or surging which may have taken place. If this is the case, one should contact their installer to remove the battery. The battery will then be take to the distributer and will then and only then be opened and inspected. | ||
+ | ==== 7.2 Battery has a flashing red light ==== | ||
+ | The battery may have an error, be it internal or externally caused. One should hold in the reset button for 5 seconds, turning the battery off and then hold in the reset button for another 5 seconds once the battery has been off for longer than 10 seconds. This will reset the battery and clear the error. If the error does not clear, one should contact their installer to remove the battery. The battery will then be take to the distributer and will then and only then be opened and inspected. | ||
+ | ==== 7.3 Battery has no voltage or 16V on the battery terminals ==== | ||
+ | The battery may have have a faulty breaker or the battery may have been subjected to a surge or lightning strike. If your inverter is reading a low battery reading, one should contact their installer to remove the battery. The battery will then be take to the distributer and will then and only then be opened and inspected. | ||
+ | ===== 8. Warranty documentation | ||
+ | All BSL batteries are subject to warranty specific documentation which can be found here: {{: | ||
+ | ===== 9. Battery Installed correctly ===== | ||
+ | Installation image courtesy of 'Get Off Grid' South Africa. | ||
===== Further Information ===== | ===== Further Information ===== | ||
+ | For more product information, | ||
For information about where to buy or find suitably qualified installers, visit the [[https:// | For information about where to buy or find suitably qualified installers, visit the [[https:// | ||
- | Further community discussion about installing and using BSL and Victron can found at [[https:// | + | Further community discussion about installing and using BSLBATT |
battery_compatibility/bsl.1618400950.txt.gz · Last modified: 2021-04-14 13:49 by guystewart
