battery_compatibility:bmz_ess
battery_compatibility:bmz_ess [2021-03-20 02:58] – guystewart | battery_compatibility:bmz_ess [2022-07-18 12:05] (current) – typo dfaber | ||
- | ====== Victron & BMZ ESS 7.0 / ESS 9.0 / ESS X===== | + | ====== Victron & BMZ ===== |
The combination of Victron products with the BMZ ESS battery has been tested and certified by the R&D departments. The combination is actively supported by both companies. | The combination of Victron products with the BMZ ESS battery has been tested and certified by the R&D departments. The combination is actively supported by both companies. | ||
+ | * ESS 7.0 | ||
+ | * ESS 9.0 | ||
+ | * ESS X | ||
+ | * ESS Z | ||
Line 40: | Line 47: | ||
- BMZ ESS 9.0 - 156.6 Ah | - BMZ ESS 9.0 - 156.6 Ah | ||
- BMZ ESS X - 186.3 Ah | - BMZ ESS X - 186.3 Ah | ||
+ | - BMZ ESS Z - 162 Ah | ||
- The other parameters (" | - The other parameters (" | ||
Line 65: | Line 73: | ||
==== 5. GX device Configuration ==== | ==== 5. GX device Configuration ==== | ||
- | * Select the //CAN-bus BMS (500 kbits/s)// CAN-profile in the [[venus-os: | + | * Select the //CAN-bus BMS (500 kbits/s)// CAN-profile in the [[venus-os: |
* After properly wiring and setting up, the BMZ ESS will be visible as a battery in the device list:{{ : | * After properly wiring and setting up, the BMZ ESS will be visible as a battery in the device list:{{ : |
battery_compatibility/bmz_ess.1616205538.txt.gz · Last modified: 2021-03-20 02:58 by guystewart
