battery_compatibility:bmz_ess
battery_compatibility:bmz_ess [2018-02-07 11:05] – martijncoster | battery_compatibility:bmz_ess [2022-07-18 12:05] (current) – typo dfaber | ||
+ | * ESS 7.0 | ||
+ | * ESS 9.0 | ||
+ | * ESS X | ||
+ | * ESS Z | ||
- | All 48V Multis and Quattros. And always a Venus device is necessary in the system, since that has the canbus port which is used for the (required!) communication between the ESS battery and the Victron system. | + | All 48V Multis and Quattros. And always a [[venus-os: |
Line 11: | Line 18: | ||
- | * BMZ batteries and MPPT Solar Chargers with a VE.Can communication port cannot be both connected to the CCGX, because of different canbus speeds. Use Solar Chargers with a VE.Direct comm. port instead. | + | * BMZ batteries and MPPT Solar Chargers with a VE.Can communication port cannot be both connected to the CCGX, because of different canbus speeds. Use a Cerbo GX, or Solar Chargers with a VE.Direct comm. port instead. |
- | ==== 2. Venus device needed ==== | + | ==== 2. GX device needed ==== |
- | To use the BMZ ESS in Victron system, it is necessary to use a Color Control GX or Venus GX. The Venus device takes care of sending | + | To use the BMZ ESS in Victron system, it is necessary to use a Color Control GX or Venus GX. On first commissioning an external power supply (Not the 48V from the BMZ-Battery) is needed. The GX device sends a keep alive signal |
==== 3. Wiring of communication cables ==== | ==== 3. Wiring of communication cables ==== | ||
- | Use the //VE.Can to CAN-bus BMS type B Cable//, part number ASS030720018. Plug the side which is labeled Battery BMS into the BMZ BMS. Plug the side labeled Victron VE.Can into the Venus-device. | + | Use the //VE.Can to CAN-bus BMS type B Cable//, part number ASS030720018. Plug the side which is labeled Battery BMS into the BMZ BMS. Plug the side labeled Victron VE.Can into the [[venus-os: |
- | Without properly connecting this cable, the battery will stop charging/ | + | Without properly connecting this cable, the battery will stop charging/ |
Line 36: | Line 44: | ||
- Check " | - Check " | ||
- | - BMZ ESS 3.0 - 121.5 Ah | ||
- BMZ ESS 7.0 - 121.5 Ah | - BMZ ESS 7.0 - 121.5 Ah | ||
+ | - BMZ ESS 9.0 - 156.6 Ah | ||
+ | - BMZ ESS X - 186.3 Ah | ||
+ | - BMZ ESS Z - 162 Ah | ||
- The other parameters (" | - The other parameters (" | ||
Line 61: | Line 71: | ||
- | ==== 5. Venus device Configuration ==== | + | ==== 5. GX device Configuration ==== |
- | * Select the //CAN-bus BMS (500 kbits/s)// CAN-profile in the Venus device. Menu path: //Settings -> Services -> CAN-profile// | + | * Select the //CAN-bus BMS (500 kbits/s)// CAN-profile in the [[venus-os: |
battery_compatibility/bmz_ess.1517997936.txt.gz · Last modified: 2018-02-07 11:05 by martijncoster
