battery_compatibility:bmz_ess
battery_compatibility:bmz_ess [2017-08-29 08:45] – [4. Color Control GX Configuration] edevries | battery_compatibility:bmz_ess [2022-07-18 12:05] (current) – typo dfaber | ||
+ | * ESS 7.0 | ||
+ | * ESS 9.0 | ||
+ | * ESS X | ||
+ | * ESS Z | ||
- | All 48V Multis and Quattros. And always a Color Control | + | All 48V Multis and Quattros. And always a [[venus-os: |
Line 11: | Line 18: | ||
- | * BMZ batteries and MPPT Solar Chargers with a VE.Can communication port cannot be both connected to the CCGX, because of different canbus speeds. Use Solar Chargers with a VE.Direct comm. port instead. | + | * BMZ batteries and MPPT Solar Chargers with a VE.Can communication port cannot be both connected to the CCGX, because of different canbus speeds. Use a Cerbo GX, or Solar Chargers with a VE.Direct comm. port instead. |
- | ==== 2. Wiring of communication cables ==== | ||
- | To use the BMZ ESS in Victron system, it is necessary to use a Color Control GX. The Color Control GX takes care of sending the necessary canbus keep-a-live message to the ESS battery. Without it, the battery will open its internal emergency relay after 10 minutes. | ||
- | A special RJ-45 cable is necessary to connect the battery to the Color Control GX. Pinout: | + | ==== 2. GX device needed ==== |
+ | To use the BMZ ESS in Victron system, it is necessary to use a Color Control | ||
- | ^ Function ^ VE.Can RJ-45 ^ BMZ ESS RJ-45 ^ | ||
- | | GND | Pin 3 | Pin 2 | | ||
- | | CAN-L | ||
- | | CAN-H | ||
- | Place a VE.Can | + | ==== 3. Wiring of communication cables ==== |
+ | Use the //VE.Can | ||
- | ==== 3. VEConfigure settings ==== | + | Then, plug a [[https:// |
- | === 3.1 General tab === | + | More information about the cable can be found in [[battery_compatibility: |
- | - Enabled | + | |
+ | Without properly connecting this cable, the battery will stop charging/ | ||
+ | ==== 4. VEConfigure settings ==== | ||
+ | - Check " | ||
- | - BMZ ESS 3.0 - 121.5 Ah | ||
- BMZ ESS 7.0 - 121.5 Ah | - BMZ ESS 7.0 - 121.5 Ah | ||
+ | - BMZ ESS 9.0 - 156.6 Ah | ||
+ | - BMZ ESS X - 186.3 Ah | ||
+ | - BMZ ESS Z - 162 Ah | ||
+ | - The other parameters (" | ||
- | === 3.2 Charger tab === | + | === 4.2 Charger tab === |
| Battery type | Lithium | | | Battery type | Lithium | | ||
Line 48: | Line 60: | ||
Note: make sure to double check the float voltage after completing Assistants, and if necessary set it back to 60.00 V. | Note: make sure to double check the float voltage after completing Assistants, and if necessary set it back to 60.00 V. | ||
- | === 3.3 ESS Assistant === | + | === 4.3 ESS Assistant === |
Select the fourth battery type: | Select the fourth battery type: | ||
Line 59: | Line 71: | ||
- | ==== 4. Color Control | + | ==== 5. GX device |
- | * Select the //CAN-bus BMS (500 kbits/s)// CAN-profile in the CCGX. Menu path: //Settings -> Services -> CAN-profile// | + | * Select the //CAN-bus BMS (500 kbits/s)// CAN-profile in the [[venus-os: |
battery_compatibility/bmz_ess.1503989101.txt.gz · Last modified: 2017-08-29 08:45 by edevries
