battery_compatibility:bmz_ess
| battery_compatibility:bmz_ess [2021-03-20 01:58] – guystewart | battery_compatibility:bmz_ess [2022-07-18 10:05] (current) – typo dfaber | ||
| Line 1: | Line 1: | ||
| - | ====== Victron & BMZ ESS 7.0 / ESS 9.0 / ESS X===== | + | ====== Victron & BMZ ===== |
| The combination of Victron products with the BMZ ESS battery has been tested and certified by the R&D departments. The combination is actively supported by both companies. | The combination of Victron products with the BMZ ESS battery has been tested and certified by the R&D departments. The combination is actively supported by both companies. | ||
| + | Compatible BMZ models: | ||
| + | * ESS 7.0 | ||
| + | * ESS 9.0 | ||
| + | * ESS X | ||
| + | * ESS Z | ||
| ==== 1. Introduction ==== | ==== 1. Introduction ==== | ||
| Line 40: | Line 47: | ||
| - BMZ ESS 9.0 - 156.6 Ah | - BMZ ESS 9.0 - 156.6 Ah | ||
| - BMZ ESS X - 186.3 Ah | - BMZ ESS X - 186.3 Ah | ||
| + | - BMZ ESS Z - 162 Ah | ||
| - The other parameters (" | - The other parameters (" | ||
| Line 65: | Line 73: | ||
| ==== 5. GX device Configuration ==== | ==== 5. GX device Configuration ==== | ||
| - | * Select the //CAN-bus BMS (500 kbits/s)// CAN-profile in the [[venus-os: | + | * Select the //CAN-bus BMS (500 kbits/s)// CAN-profile in the [[venus-os: |
| * After properly wiring and setting up, the BMZ ESS will be visible as a battery in the device list:{{ : | * After properly wiring and setting up, the BMZ ESS will be visible as a battery in the device list:{{ : | ||
battery_compatibility/bmz_ess.1616205538.txt.gz · Last modified: by guystewart
