battery_compatibility:bmz_ess
battery_compatibility:bmz_ess [2020-01-31 07:29] – alexander.joist_ibc-solar.co.za | battery_compatibility:bmz_ess [2022-07-18 12:05] (current) – typo dfaber | ||
- | ====== Victron & BMZ ESS 7.0 / ESS 9.0 / ESS X===== | + | ====== Victron & BMZ ===== |
The combination of Victron products with the BMZ ESS battery has been tested and certified by the R&D departments. The combination is actively supported by both companies. | The combination of Victron products with the BMZ ESS battery has been tested and certified by the R&D departments. The combination is actively supported by both companies. | ||
+ | * ESS 7.0 | ||
+ | * ESS 9.0 | ||
+ | * ESS X | ||
+ | * ESS Z | ||
Line 11: | Line 18: | ||
- | * BMZ batteries and MPPT Solar Chargers with a VE.Can communication port cannot be both connected to the CCGX, because of different canbus speeds. Use Solar Chargers with a VE.Direct comm. port instead. | + | * BMZ batteries and MPPT Solar Chargers with a VE.Can communication port cannot be both connected to the CCGX, because of different canbus speeds. Use a Cerbo GX, or Solar Chargers with a VE.Direct comm. port instead. |
Line 20: | Line 27: | ||
==== 2. GX device needed ==== | ==== 2. GX device needed ==== | ||
- | To use the BMZ ESS in Victron system, it is necessary to use a Color Control GX or Venus GX. On first commissioning an external power supply (Not the 48V from the BMZ-Battery) is needed. The CCGX/ | + | To use the BMZ ESS in Victron system, it is necessary to use a Color Control GX or Venus GX. On first commissioning an external power supply (Not the 48V from the BMZ-Battery) is needed. The GX device |
Line 26: | Line 33: | ||
Use the //VE.Can to CAN-bus BMS type B Cable//, part number ASS030720018. Plug the side which is labeled Battery BMS into the BMZ BMS. Plug the side labeled Victron VE.Can into the [[venus-os: | Use the //VE.Can to CAN-bus BMS type B Cable//, part number ASS030720018. Plug the side which is labeled Battery BMS into the BMZ BMS. Plug the side labeled Victron VE.Can into the [[venus-os: | ||
Line 40: | Line 47: | ||
- BMZ ESS 9.0 - 156.6 Ah | - BMZ ESS 9.0 - 156.6 Ah | ||
- BMZ ESS X - 186.3 Ah | - BMZ ESS X - 186.3 Ah | ||
+ | - BMZ ESS Z - 162 Ah | ||
- The other parameters (" | - The other parameters (" | ||
Line 65: | Line 73: | ||
==== 5. GX device Configuration ==== | ==== 5. GX device Configuration ==== | ||
- | * Select the //CAN-bus BMS (500 kbits/s)// CAN-profile in the [[venus-os: | + | * Select the //CAN-bus BMS (500 kbits/s)// CAN-profile in the [[venus-os: |
* After properly wiring and setting up, the BMZ ESS will be visible as a battery in the device list:{{ : | * After properly wiring and setting up, the BMZ ESS will be visible as a battery in the device list:{{ : |
