battery_compatibility:bmz_ess
battery_compatibility:bmz_ess [2019-08-15 12:13] – replace venus-device with GX device guy_stewart | battery_compatibility:bmz_ess [2020-01-31 07:29] – alexander.joist_ibc-solar.co.za | ||
- | ====== Victron & BMZ ESS 3.0 / ESS 7.0 ===== | + | ====== Victron & BMZ ESS 7.0 / ESS 9.0 / ESS X===== |
Line 37: | Line 37: | ||
- Check " | - Check " | ||
- | - BMZ ESS 3.0 - 121.5 Ah | + | - BMZ ESS 7.0 - 121.5 Ah |
- | - BMZ ESS 7.0 - 156.6 Ah | + | - BMZ ESS 9.0 - 156.6 Ah |
- BMZ ESS X - 186.3 Ah | - BMZ ESS X - 186.3 Ah | ||
- The other parameters (" | - The other parameters (" | ||
Line 70: | Line 70: | ||
