battery_compatibility:bmz_ess
battery_compatibility:bmz_ess [2017-04-13 10:03] – bob-victron | battery_compatibility:bmz_ess [2021-06-14 10:57] – bob | ||
+ | * ESS 7.0 | ||
+ | * ESS 9.0 | ||
+ | * ESS X | ||
+ | * ESS Z | ||
- | All 48V Multis and Quattros. And always a Color Control | + | All 48V Multis and Quattros. And always a [[venus-os: |
Line 11: | Line 18: | ||
+ | * BMZ batteries and MPPT Solar Chargers with a VE.Can communication port cannot be both connected to the CCGX, because of different canbus speeds. Use a Cerbo GX, or Solar Chargers with a VE.Direct comm. port instead. | ||
- | ==== 2. Wiring of communication cables | + | ==== 2. GX device needed |
- | To use the BMZ ESS in Victron system, it is necessary to use a Color Control GX. The Color Control GX takes care of sending | + | To use the BMZ ESS in Victron system, it is necessary to use a Color Control |
- | A special RJ-45 cable is necessary to connect the battery to the Color Control GX. Pinout: | ||
- | ^ Function ^ VE.Can | + | ==== 3. Wiring of communication cables ==== |
- | | GND | Pin 3 | Pin 2 | | + | Use the //VE.Can |
- | | CAN-L | + | |
- | | CAN-H | + | |
- | Place a VE.Can terminator in the empty socket on the CCGX | + | Then, plug a [[https:// |
- | ==== 3. VEConfigure settings ==== | + | More information about the cable can be found in [[battery_compatibility: |
- | === 3.1 Charge tab === | + | |
+ | Without properly connecting this cable, the battery will stop charging/ | ||
+ | ==== 4. VEConfigure settings ==== | ||
+ | - Check " | ||
+ | - Enter the battery capacity: | ||
+ | - BMZ ESS 7.0 - 121.5 Ah | ||
+ | - BMZ ESS 9.0 - 156.6 Ah | ||
+ | - BMZ ESS X - 186.3 Ah | ||
+ | - BMZ ESS Z - 162 Ah | ||
+ | - The other parameters (" | ||
+ | === 4.2 Charger | ||
| Battery type | Lithium | | | Battery type | Lithium | | ||
Line 41: | Line 60: | ||
Note: make sure to double check the float voltage after completing Assistants, and if necessary set it back to 60.00 V. | Note: make sure to double check the float voltage after completing Assistants, and if necessary set it back to 60.00 V. | ||
- | === 3.2 ESS Assistant === | + | === 4.3 ESS Assistant === |
Select the fourth battery type: | Select the fourth battery type: | ||
Line 47: | Line 66: | ||
Then: | Then: | ||
- | - Enter the battery capacity: | ||
- | - BMZ ESS 3.0 - 121.5 Ah | ||
- | - BMZ ESS 7.0 - 121.5 Ah | ||
- Do not change the dynamic cut-off values, they have already been set correctly after selecting the lithium battery type. | - Do not change the dynamic cut-off values, they have already been set correctly after selecting the lithium battery type. | ||
+ | - Sustain voltage: 50V | ||
- Same for the restart offset: do not change that. | - Same for the restart offset: do not change that. | ||
- | ==== 4. Color Control | + | ==== 5. GX device |
- | * Enable | + | * Select |
- | * Make sure to enable the // | + | |
