battery_compatibility:bmz_ess
battery_compatibility:bmz_ess [2017-03-01 11:33] – [Victron & BMZ ESS 3.0 / ESS 7.0] mvaderbattery_compatibility:bmz_ess [2022-07-18 12:05] (current) – typo dfaber
-====== Victron & BMZ ESS 3.0 / ESS 7.0 =====+====== Victron & BMZ =====
 +The combination of Victron products with the BMZ ESS battery has been tested and certified by the R&D departmentsThe combination is actively supported by both companies.
 +Compatible BMZ models:
 +  * ESS 7.0
 +  * ESS 9.0
 +  * ESS X
 +  * ESS Z
-The combination of Victron products with the BMZ ESS 7.0 battery has been tested and certified by the R&D departments. The combination is actively supported by both companies.
 ==== 1. Introduction ==== ==== 1. Introduction ====
 === 1.1 Compatible Victron products === === 1.1 Compatible Victron products ===
-All 48V Multis and Quattros. And always a Color Control GX is necessary in the system, since that has the canbus port which is used for the (required!) communication between the ESS battery and the Victron system.+All 48V Multis and Quattros. And always a [[venus-os:start|GX device]] is necessary in the system, since that has the canbus port which is used for the (required!) communication between the ESS battery and the Victron system.
 === 1.2 Notes === === 1.2 Notes ===
Line 10: Line 18:
   * Paralleling multiple BMZ ESS batteries to expand capacity is possible. Contact BMZ for more information.   * Paralleling multiple BMZ ESS batteries to expand capacity is possible. Contact BMZ for more information.
   * Derating, based on the dynamic BMZ ESS charge- and discharge limits:   * Derating, based on the dynamic BMZ ESS charge- and discharge limits:
-    * Minimum CCGX version is v1.72    +    * Minimum GX device version is v1.72
     * The derating mechanism is not very precise yet. In other words, do not expect a discharge limit of 30A to result in a precise discharge of 30A.     * The derating mechanism is not very precise yet. In other words, do not expect a discharge limit of 30A to result in a precise discharge of 30A.
     * Actual charge- and discharge limits are visible in the Parameters page. See screenshot below in Chapter 4.     * Actual charge- and discharge limits are visible in the Parameters page. See screenshot below in Chapter 4.
 +  * BMZ batteries and MPPT Solar Chargers with a VE.Can communication port cannot be both connected to the CCGX, because of different canbus speeds. Use a Cerbo GX, or Solar Chargers with a VE.Direct comm. port instead.
 === 1.3 System diagram === === 1.3 System diagram ===
 {{ :battery_compatibility:hub4-1phase-bmzess.png?nolink |}} {{ :battery_compatibility:hub4-1phase-bmzess.png?nolink |}}
-==== 2. Wiring of communication cables ==== +==== 2. GX device needed ====
-To use the BMZ ESS in Victron system, it is necessary to use a Color Control GX. The Color Control GX takes care of sending the necessary canbus keep-a-live message to the ESS battery. Without it, the battery will open its internal emergency relay after 10 minutes.+To use the BMZ ESS in Victron system, it is necessary to use a Color Control GX or Venus GX. On first commissioning an external power supply (Not the 48V from the BMZ-Battery) is needed. The GX device sends keep alive signal to the BMZ ESS via canbus. This will only be send once the canbus baud rate is changed (see 5. [[venus-os:start|GX device]] Configuration). Without it, the battery will have a communication fault and shut down after 10sec.
-A special RJ-45 cable is necessary to connect the battery to the Color Control GX. Pinout:
-^ Function ^ VE.Can RJ-45 ^ BMZ ESS RJ-45 ^ +==== 3. Wiring of communication cables ====
-| GND      | Pin 3        | Pin 2         | +Use the //VE.Can to CAN-bus BMS type B Cable//, part number ASS030720018. Plug the side which is labeled Battery BMS into the BMZ BMS. Plug the side labeled Victron VE.Can into the [[venus-os:start|GX device]].
-| CAN-L    | Pin 8        | Pin 5         | +
-| CAN-H    | Pin 7        | Pin 4         |+
-Place a VE.Can terminator in the empty socket on the CCGX+Then, plug [[https://www.victronenergy.com/accessories/ve-can-rj45-terminator|VE.Can terminator]] in the other VE.Can socket on the [[venus-os:start|GX device]]. Two VE.Can terminators are included with the package of the GX device as an accessory, only one is used. Keep the other one as a spare.
-==== 3. VEConfigure settings ==== +More information about the cable can be found in [[battery_compatibility:can-bus_bms-cable|its manual]].
-=== 3.1 Charge tab ===+
 +Without properly connecting this cable, the battery will stop charging/discharging after several minutes. Also, the battery will not show up on the display of the [[venus-os:start|GX device]].
 +==== 4. VEConfigure settings ====
 +=== 4.1 General tab ===
 +  - Check "Enable battery monitor"
 +  - Enter the battery capacity:
 +    - BMZ ESS 7.0 - 121.5 Ah
 +    - BMZ ESS 9.0 - 156.6 Ah
 +    - BMZ ESS X - 186.3 Ah
 +    - BMZ ESS Z - 162 Ah
 +  - The other parameters ("State of charge when bulk finished" and "Charge efficiency") can be left to their default setting. They are not used in this setup.
 +=== 4.2 Charger tab ===
 ^ Parameter              ^ Setting ^ ^ Parameter              ^ Setting ^
 | Battery type           | Lithium | | Battery type           | Lithium |
Line 40: Line 60:
 Note: make sure to double check the float voltage after completing Assistants, and if necessary set it back to 60.00 V. Note: make sure to double check the float voltage after completing Assistants, and if necessary set it back to 60.00 V.
-=== 3.ESS Assistant ===+=== 4.ESS Assistant ===
 Select the fourth battery type: Select the fourth battery type:
Line 46: Line 66:
 Then: Then:
-  - Enter the battery capacity:
-    - BMZ ESS 3.0 - 121.5 Ah
-    - BMZ ESS 7.0 - 121.5 Ah
   - Do not change the dynamic cut-off values, they have already been set correctly after selecting the lithium battery type.   - Do not change the dynamic cut-off values, they have already been set correctly after selecting the lithium battery type.
 +  - Sustain voltage: 50V
   - Same for the restart offset: do not change that.   - Same for the restart offset: do not change that.
-==== 4Color Control GX Configuration ====+==== 5. GX device Configuration ====
-  * Enable the CAN-bus BMS Service in the CCGX. Menu path: //Settings -> Services -> CAN-bus BMS//. Note that this changes the function of a VE.Can port: it is not possible to connect both VE.Can products and a BMZ battery together.+  * Select the //CAN-bus BMS (500 kbits/s)// CAN-profile in the [[venus-os:start|GX device]]. Menu path: //Settings -> Services -> CAN-profile//. Note that this changes the function of a VE.Can port: it is not possible to connect both VE.Can products and a BMZ battery together on a Color Control GX. It is possible on the Venus GX.
   * After properly wiring and setting up, the BMZ ESS will be visible as a battery in the device list:{{ :battery_compatibility:generic_battery_menu.png?nolink&290 | }}   * After properly wiring and setting up, the BMZ ESS will be visible as a battery in the device list:{{ :battery_compatibility:generic_battery_menu.png?nolink&290 | }}
   * The parameters option within the battery page shows the actual battery charge and discharge limits:{{ :battery_compatibility:batteryparameters.png?nolink&290 | }}   * The parameters option within the battery page shows the actual battery charge and discharge limits:{{ :battery_compatibility:batteryparameters.png?nolink&290 | }}
-  * Make sure to enable the //Synchronize VE.Bus SOC with battery// setting in the System Setup page in the CCGX: it will copy the State of Charge as reported by the BMZ ESS to the Multi or Quattro, making Hub-4 work with that SOC.+
 +==== 6DVCC Settings ====
 +Enabling DVCC changes a GX device from a passive monitor into an active controller. The available features and effects of enabling DVCC depend on the type of battery used. The effect also depends on the installed Victron components and their configuration.
 +This table shows the recommend settings for different battery types:
 +{{ :ccgx:dvcc_table2.png?nolink&800 |}}
 ~~DISQUS~~ ~~DISQUS~~
