battery_compatibility:bluenova
battery_compatibility:bluenova [2020-06-22 10:46] – [5. Color Control GX Configuration] rickerts_bluenova.co.za | battery_compatibility:bluenova [2022-04-07 10:40] (current) – dirkbluenova | ||
Line 5: | Line 5: | ||
=== 1.1 Product and System Compatibility === | === 1.1 Product and System Compatibility === | ||
- | Victron + BlueNova can be used for the following systems | + | Victron + BlueNova |
1.Off Grid | 1.Off Grid | ||
2.Backup | 2.Backup | ||
3.Energy Storage | 3.Energy Storage | ||
- | === 1.2 Colour Control | + | === 1.2 GX device |
- | When used with BlueNova Batteries the minimum | + | When used with BlueNova |
- | === 1.3 All 48V Multi’s, MultiPlus, MultiPlus II, Multigrids | + | === 1.3 All 48V Multi’s, MultiPlus, MultiPlus II, Multigrids, Quattros |
- | When the BlueNova battery is installed in a Victron ESS installation, | + | When the BlueNova |
Line 23: | Line 25: | ||
==== 2.BlueNova Energy product range ==== | ==== 2.BlueNova Energy product range ==== | ||
- | The BlueNova range is supplied with a BMS as standard on all current | + | The BlueNova |
- | ==== 3. Wiring of Can.Bus cable between BlueNova and CCGX. ==== | + | ==== 3. Wiring of Can.Bus cable between BlueNova |
- | {{https:// | ||
No RJ45 cable is supplied for this connection . | No RJ45 cable is supplied for this connection . | ||
- | Plug the CCGX/ | + | Plug the GX device |
- | Without properly connecting this cable, the battery will stop charging/ | + | For BlueNova |
+ | Without properly connecting this cable, the battery will stop charging/ | ||
+ | To view more information on the RacPower | ||
Line 47: | Line 57: | ||
=== 4.1 Charge parameters === | === 4.1 Charge parameters === | ||
- | {{https:// | + | {{: |
Line 58: | Line 73: | ||
=== 4.2 ESS Assistant === | === 4.2 ESS Assistant === | ||
- | Select the fourth | + | Select the fifth battery type: |
Line 66: | Line 81: | ||
- | ==== 5. Color Control | + | ==== 5. GX device |
- | Select the //VE.Can & CAN-bus BMS (250 kbaud)// CAN-profile in the CCGX. Menu path: //Settings -> Services -> CAN-profile// | + | In most cases nothing needs changing: new Blue Nova Energy batteries come with 500kbps |
+ | In case a setting does need changing, such as setting a different baud rate or configuring a VE.Can port to be used for BMS-Can instead, use the menu path //Settings -> Services -> CAN-profile// | ||
+ | Note that it is not possible | ||
+ | All BlueNova Energy products can work with either 250kbps or 500kbps. On the older batteries this mean installing new firmware and on the new batteries this is selectable on the user interface on the battery. The default baud rate on newly delivered BlueNova Energy batteries 500kbps. | ||
Line 77: | Line 98: | ||
- | After properly wiring and setting up, the BlueNova will be visible as a battery in the device list: | + | After properly wiring and setting up, the BlueNova |
Line 106: | Line 127: | ||
If you have multiple batteries, a single entry will show up, which represents all batteries. | If you have multiple batteries, a single entry will show up, which represents all batteries. | ||
The parameters option within the battery page shows the actual battery charge and discharge limits. | The parameters option within the battery page shows the actual battery charge and discharge limits. | ||
+ | To be able to monitor all individual paralleled BlueNova Energy batteries in an installation, | ||
+ | (The BlueNova Energy BMAC Online unit can be purchased seperately from your BlueNova Energy registered installer or dealer.) | ||
- | ==== **6.** **BlueNova Energy battery setup with DVCC enabled** | + | ==== 6. BlueNova Energy battery setup with DVCC enabled |
+ | (DVCC - Distributed Voltage and Current Control) | ||
Introduction and features | Introduction and features | ||
- | Enabling | + | With the latest Victron Energy GX device firmware installed, |
+ | Activating the DVCC in this way, changes the GX device from a passive monitor into an active controller. | ||
The GX device | The GX device | ||
Line 155: | Line 182: | ||
- | BlueNova Energy | + | BlueNova Energy |
- | BlueNova Energy BMMC : V3.5 | + | BlueNova Energy BMMC : V3.5 + |
Multi/ | Multi/ | ||
Line 163: | Line 190: | ||
MultiGrid: 424 | MultiGrid: 424 | ||
- | CCGX / Venus GX: v2.12 VE.Direct MPPTs: v1.29 | + | GX device: v2.12 VE.Direct MPPTs: v1.29 |
VE.Can MPPT Solar Chargers cannot be used: they do not yet support the new control mechanisms. | VE.Can MPPT Solar Chargers cannot be used: they do not yet support the new control mechanisms. | ||
+ | (Latest VeCan /VeDirect MPPT Solar Chargers is compatible...) | ||
Lynx Ion + Shunt: v2.04 Lynx BMS: v1.09 | Lynx Ion + Shunt: v2.04 Lynx BMS: v1.09 | ||
Line 173: | Line 201: | ||
+ | ==== 7. Recommended Maximum Charge / Discharge Values ==== | ||
- | ==== 7. Configure MPPT ==== | + | ==== 8. Configure MPPT ==== |
- Disable Autodetect voltage | - Disable Autodetect voltage | ||
- Set Battery voltage to 48V. | - Set Battery voltage to 48V. | ||
Line 182: | Line 211: | ||
** - All latest GX devices applicable. | ** - All latest GX devices applicable. | ||
- | ~~DISQUS~~ | + | |
battery_compatibility/bluenova.1592815570.txt.gz · Last modified: 2020-06-22 10:46 by rickerts_bluenova.co.za
