battery_compatibility:aquion_ahi
battery_compatibility:aquion_ahi [2016-03-25 09:45] – created mvader | battery_compatibility:aquion_ahi [2019-02-18 11:00] (current) – guy_stewart | ||
- | ====== Victron & Aquion | + | Aquion |
- | **Note: this is a draft!** | + | [[https://www.victronenergy.com/ |
- | ===== Compatible Victron products ===== | + | |
- | All 48V Multis and Quattros. Also all MPPT Solar chargers that can work with a 48V battery. | + | |
- | Note that there is no integration in the Color Control GX required nor available: it will not (yet) read data directly from the Aquion AHI BMS. | + | |
- | ===== Configuration ===== | + | |
- | ^ Parameter | + | |
- | | Charge curve | Fixed | | + | |
- | | Absorption voltage | + | |
- | | Float voltage | + | |
- | | Storage | + | |
- | | Charge current | + | |
- | | Repeated absorption time | 1 hr | | + | |
- | | Repeated absorption interval | Not required | | + | |
- | | Max absorption time | 1 hrs | | + | |
- | | Low voltage disconnect | + | |
- | (1) The storage setting will make the charger lower the voltage to 52.8 V, after first staying in float for 24 hours. | + | |
- | (2) Under normal conditions, all the energy should be discharged when you reach 40V. However, during short high current | + | |
battery_compatibility/aquion_ahi.txt · Last modified: 2019-02-18 11:00 by guy_stewart
