battery_compatibility:aquion_ahi
battery_compatibility:aquion_ahi [2019-01-21 10:38] – [DISQUS] ictbeheer | battery_compatibility:aquion_ahi [2019-02-18 10:40] – [Configuration] marianka | ||
- | ====== Victron & Aquion AHI ===== | + | ====== Victron & GREENROCK |
===== Compatible Victron products ===== | ===== Compatible Victron products ===== | ||
All 48V Multis and Quattros. Also all MPPT Solar chargers that can work with a 48V battery. | All 48V Multis and Quattros. Also all MPPT Solar chargers that can work with a 48V battery. | ||
- | Note that there is no integration in the Color Control GX required nor available: it will not (yet) read data directly from the Aquion AHI BMS. | + | Note that there is no integration in the Color Control GX required nor available: it will not (yet) read data directly from the GREENROCK |
Line 12: | Line 12: | ||
| Float voltage | | Float voltage | ||
| Storage | | Storage | ||
- | | Charge current | + | | Charge current |
| Repeated absorption time | 4 hrs | 4 hrs | | | Repeated absorption time | 4 hrs | 4 hrs | | ||
| Repeated absorption interval | Not required | | Repeated absorption interval | Not required | ||
Line 24: | Line 24: | ||
Make sure to lower the Dynamic Cut-off parameters, to 37.5, 37.4, 37.3 and 37.2. | Make sure to lower the Dynamic Cut-off parameters, to 37.5, 37.4, 37.3 and 37.2. | ||
+ | ~~DISQUS~~ | ||
battery_compatibility/aquion_ahi.txt · Last modified: 2019-02-18 11:00 by guy_stewart
