auto-generator-start-stop:start [2015-08-20 11:04] – mvaderauto-generator-start-stop:start [2021-02-25 12:46] (current) – marmour
-====== Generator auto start/stop ====== +This page has been moved to manual [[https://www.victronenergy.com/media/pg/Automatic_Generator_start-stop/en/index-en.html|Automatic Generator Start/Stop]].
-There are many ways to automatically start and stop a generator using Victron equipment: +
-  - potential free relay in a BMV-700. Start the generator on low battery voltage and/or low battery state of charge. See the [[http://www.victronenergy.com/battery-monitors/bmv-700#manual|BMV-700 manual]] for configuration. +
-  - potential free relay in our Inverters, Multis and Quattros, using the Virtual switch +
-  - potential free relay(s) in our Inverters, Multis and Quattros, using the [[assistants:overview_of_available_assistants#generator_start_and_stop|Generator start/stop Assistant]] +
-  - (Expected in October 2015) [[ccgx:generator_start_stop|Automatic start stop from the Color Control GX]] +
-It is also possible to combine above mentioned methods, by wiring the open contacts in parallel to each other.  +
-===== Starting a genset with three-wire interface ===== +
-To start such a genset, our the open/close contact needs to be converted into a start and stop pulse. Below solution, using standard available timing relays, does exactly that: when the open/close contact closes it generates the start pulse, and when the open/close contact opens again it generates the stop pulse.  +
-Note that this solution should only be used on generators that do have a control panel monitoring and automatically stopping on loss of oil pressure and other sensors. In other words: do not wire this directly to the starter motor and fuel solenoid. +
-[add image with block diagram ] +
-[ add image with wiring diagram]  +
-===== DISQUS ===== +
-~~DISQUS~~+
auto-generator-start-stop/start.1440068686.txt.gz · Last modified: by mvader
