auto-generator-start-stop:start [2019-01-27 00:57] – mvader | auto-generator-start-stop:start [2019-08-29 15:39] – external edit 127.0.0.1 | ||
Line 5: | Line 5: | ||
Various Victron products have functions to automatically signal when to start and stop a generator. Here is advice on when to use which product and method. | Various Victron products have functions to automatically signal when to start and stop a generator. Here is advice on when to use which product and method. | ||
- | When there is a [[venus-os: | ||
+ | === Option 1: GX device like CCGX or Venus GX === | ||
+ | When there is a [[venus-os: | ||
+ | === Option 2: BMV Battery Monitor === | ||
The next most used option is a BMV-700 Battery Monitor or similar model. It can start the generator on low battery voltage and/or low battery state of charge. See the [[https:// | The next most used option is a BMV-700 Battery Monitor or similar model. It can start the generator on low battery voltage and/or low battery state of charge. See the [[https:// | ||
+ | === Option 3: Using the relay in the Multis or Quattros === | ||
The Multis, MultiPlus-IIs, | The Multis, MultiPlus-IIs, | ||
Line 14: | Line 18: | ||
- [[assistants: | - [[assistants: | ||
+ | === Combining the options === | ||
Lastly, its of course also possible to combine above mentioned methods, by wiring the open contacts in parallel to each other, or in series, to the Generator. | Lastly, its of course also possible to combine above mentioned methods, by wiring the open contacts in parallel to each other, or in series, to the Generator. | ||
- | ==== 2. How to wire a a genset with three-wire interface ==== | + | ==== 2. How to wire generators with a three-wire interface ==== |
- | All above products and devices have a single relay; | + | All above Victron |
When having a generator that requires a start pulse and a stop pulse, such as for example Cummins/ | When having a generator that requires a start pulse and a stop pulse, such as for example Cummins/ | ||
Line 30: | Line 35: | ||
- | ==== Alternative using Assistants === | + | === Alternative using Assistants === |
(provided by Thierry Cortasa) | (provided by Thierry Cortasa) | ||
- | hy | + | hi |
just for information, | just for information, |
