auto-generator-start-stop:start [2018-12-08 14:59] – [Automatic Generator start/stop] guy_stewart | auto-generator-start-stop:start [2021-02-15 09:50] – marmour | ||
- | ====== Automatic Generator start/stop ====== | + | This page has been moved to [[https:// |
- | Various Victron products have functions | + | |
- | When there is a [[venus-os: | + | |
- | The next most used option is a BMV-700 Battery Monitor or similar model. It can start the generator on low battery voltage and/or low battery state of charge. See the [[https:// | + | |
- | Also the VE.Bus Inverters, Multis | + | |
- | Lastly, its of course also possible to combine above mentioned methods, by wiring the open contacts in parallel to each other, or in series, to the Generator. | + | |
- | ===== Starting a genset with three-wire interface ===== | + | |
- | For example Cummins/ | + | |
- | To start such a genset, the open/close contact needs to be converted into a start and stop pulse. Below solution, using standard available timing relays, does exactly that: when the open/close contact closes it generates the start pulse, and when the open/close contact opens again it generates the stop pulse. | + | |
- | Note that this solution should only be used on gensets that have their OWN control panel monitoring and automatically stopping on loss of oil pressure and other sensors. In other words: do not wire this directly to the starter motor and fuel solenoid. | + | |
