assistants:start
assistants:start [2014-08-03 11:57] – [I don't see the Assistants tab, how do I get it?] mvader | assistants:start [2019-03-18 21:43] (current) – mvader | ||
- | ====== Assistants ====== | + | ====== |
Line 5: | Line 5: | ||
==== What are Assistants? ==== | ==== What are Assistants? ==== | ||
- | Think of Assistants as apps, as on a smart phone. Assistants are little applications that run inside a VE.Bus Multi, Inverter or Quattro. They reduce the overall cost of a system: in 99% of all installations it will not be necessary to add an additional PLC to get for example load shedding, optimizing use of solar energy or automatically starting and stopping a genset. | + | Think of Assistants as apps, as on a smart phone. Assistants are little applications that run inside a VE.Bus Multi, Inverter or Quattro. They reduce the overall cost of a system: in 99% of all installations it will not be necessary to add an additional PLC (Programmable Logic Controller) |
- | In advanced systems you can also combine multiple assistants, it can even be usefull | + | In advanced systems you can also combine multiple assistants, it can even be useful |
To get a better understanding of the possibilities, | To get a better understanding of the possibilities, | ||
Line 15: | Line 15: | ||
VE.Bus Multis, Inverters and Quattros must be loaded with 2xx or 3xx firmware in order to get the Assistants tab. Note that running these firmware versions disables the use of the Virtual switch tab. For 95% of all Victron installations it is not necessary to run Assistants at all. They either do not require complex logic, or the required logic is included on the Virtual switch tab. | VE.Bus Multis, Inverters and Quattros must be loaded with 2xx or 3xx firmware in order to get the Assistants tab. Note that running these firmware versions disables the use of the Virtual switch tab. For 95% of all Victron installations it is not necessary to run Assistants at all. They either do not require complex logic, or the required logic is included on the Virtual switch tab. | ||
- | More information about which firmware type to choose for an installation, | + | More information about which firmware type to choose for an installation, |
- | ==== How can I play around with Assistants? ==== | + | ==== How can I play around with Assistants |
- | - Download and install VEConfigure3. It is available for download from our [[http:// | + | - Download and install VEConfigure3. It is available for download from our [[https:// |
- Start VEConfigure3 | - Start VEConfigure3 | ||
- | - Go to 'Port selection' | + | - Go to 'Port selection' |
- Select the voltage for your fake system | - Select the voltage for your fake system | ||
- Done | - Done | ||
Line 30: | Line 32: | ||
==== What is next? ==== | ==== What is next? ==== | ||
- | * [[assistants: | ||
- | To keep posted on new Assistant | + | * [[: |
+ | * [[:assistants: | ||
+ | * [[dc_coupling: | ||
+ | ==== Combining multiple Assistants ==== | ||
+ | Multiple Assistants can be used in one unit. For example the Programmable Relay is often used multiple times. When doing so; this is how they are evaluated: | ||
+ | - an ON condition always has priority over an OFF condition | ||
+ | - multi criteria in the ON ( or OFF ) list go by the OR principle | ||
assistants/start.txt · Last modified: 2019-03-18 21:43 by mvader
