assistants:start
assistants:start [2014-08-03 11:57] – [I don't see the Assistants tab, how do I get it?] mvader | assistants:start [2019-01-22 10:16] – external edit 127.0.0.1 | ||
====== Assistants ====== | ====== Assistants ====== | ||
+ | * [[dc_coupling: | ||
- | ==== What are Assistants? ==== | ||
- | Think of Assistants as apps, as on a smart phone. Assistants are little applications that run inside a VE.Bus Multi, Inverter or Quattro. They reduce the overall cost of a system: in 99% of all installations it will not be necessary to add an additional PLC to get for example load shedding, optimizing use of solar energy or automatically starting and stopping a genset. | ||
- | In advanced systems you can also combine multiple assistants, it can even be usefull to add an assistant multiple times. The Assistant logic is executed from top to bottom, which makes it possible to create complex logic. | ||
- | To get a better understanding of the possibilities, | ||
- | ==== I don't see the Assistants tab, how do I get it? ==== | ||
- | VE.Bus Multis, Inverters and Quattros must be loaded with 2xx or 3xx firmware in order to get the Assistants tab. Note that running these firmware versions disables the use of the Virtual switch tab. For 95% of all Victron installations it is not necessary to run Assistants at all. They either do not require complex logic, or the required logic is included on the Virtual switch tab. | ||
- | More information about which firmware type to choose for an installation, | ||
- | ==== How can I play around with Assistants? ==== | ||
- | - Download and install VEConfigure3. It is available for download from our [[http:// | ||
- | - Start VEConfigure3 | ||
- | - Go to 'Port selection' | ||
- | - Select the voltage for your fake system | ||
- | - Done | ||
- | You will now see both tabs, Virtual switch and Assistants. On a real system there will always be one of both, depending of firmware type loaded. | ||
- | Note that it is even possible to make a fake three-phase and parallel system, using VE.Bus System Configurator. | ||
- | ==== What is next? ==== | ||
- | * [[assistants: | ||
- | To keep posted on new Assistant developments, | ||
assistants/start.txt · Last modified: 2019-03-18 21:43 by mvader
