assistants:self_consumption_hub-1_policy-5
assistants:self_consumption_hub-1_policy-5 [2016-08-01 14:05] – [Hub-1 - Policy 'Connected to mains, no feedback'] mvader | assistants:self_consumption_hub-1_policy-5 [2019-01-22 10:16] (current) – external edit 127.0.0.1 | ||
- | ====== Hub-1 - Policy ' | + | ====== |
+ | For new installes, this policy has been deprecated. | ||
+ | Use [[ess: | ||
This policy is intended for backup systems, with DC-coupled solar installed. Use it to make use of excess solar power: as soon as the batteries are full, AC loads will be co-powered with solar power. Power stored in the batteries will only be used to power the loads during a grid failure. | This policy is intended for backup systems, with DC-coupled solar installed. Use it to make use of excess solar power: as soon as the batteries are full, AC loads will be co-powered with solar power. Power stored in the batteries will only be used to power the loads during a grid failure. | ||
Line 37: | Line 43: | ||
assistants/self_consumption_hub-1_policy-5.1470053155.txt.gz · Last modified: 2016-08-01 14:05 by mvader
