assistants:pv-inverter-support
assistants:pv-inverter-support [2020-01-12 08:36] – [4. Related documentation] guy_stewart | assistants:pv-inverter-support [2022-08-24 18:25] – mvader | ||
Line 45: | Line 45: | ||
* the mentioned 53 Hz is the PV Inverter disconnect frequency as configured in the Assistant, default 53 Hz. | * the mentioned 53 Hz is the PV Inverter disconnect frequency as configured in the Assistant, default 53 Hz. | ||
- | ~~DISQUS~~ | ||
assistants/pv-inverter-support.txt · Last modified: 2023-10-10 11:47 by sloges
