assistants:pv-inverter-support
assistants:pv-inverter-support [2019-01-14 23:34] – [1. When to use] mvader | assistants:pv-inverter-support [2019-01-21 10:36] – [5. DISQUS] ictbeheer | ||
Line 46: | Line 46: | ||
* the mentioned 53 Hz is the PV Inverter disconnect frequency as configured in the Assistant, default 53 Hz. | * the mentioned 53 Hz is the PV Inverter disconnect frequency as configured in the Assistant, default 53 Hz. | ||
- | ===== 5. DISQUS ===== | + | |
assistants/pv-inverter-support.txt · Last modified: 2023-10-10 11:47 by sloges
