assistants:how_to_update_an_assistant
assistants:how_to_update_an_assistant [2014-08-15 21:41] – [Procedure] mvader | assistants:how_to_update_an_assistant [2019-01-21 10:36] – [Procedure] ictbeheer | ||
====== How to update an Assistant ====== | ====== How to update an Assistant ====== | ||
- | When started, and connected to the internet, VEConfigure3 will automatically download the latest versions of Assistants. | + | When started, and connected to the internet, VEConfigure3 will automatically download the latest versions of Assistants. |
- | Subscribe to our [[http:// | + | Subscribe to our [[https:// |
===== Procedure ===== | ===== Procedure ===== | ||
- | - Make sure your computer is connected to the internet | + | |
- | - Start VEConfigure3 | + | - Make sure your computer is connected to the internet |
- | - It will give a notification when new Assistants are available | + | - Start VEConfigure3 |
+ | - It will give a notification when new Assistants are available: {{ : | ||
- Connect VEConfigure3 to the system, it will read all the settings | - Connect VEConfigure3 to the system, it will read all the settings | ||
- | - A warning will appear, explaining that there is a new version of one or more of the configured Assistants.[ plaatje invoegen ] | + | - In case there is an update for one or more of the configured Assistants, a warning will appear.{{ : |
- | - All Assistants that can be updated will be in italic and marked with a star. | + | - All Assistants that can be updated will be marked with a star. |
- | - Right click the assistant, and press update | + | - Right click the assistant, and press update{{ : |
- VEConfigure3 will guide you through all the pages in the Assistant: verify the values, the settings are the same as you have configured originally. Click next until finished. | - VEConfigure3 will guide you through all the pages in the Assistant: verify the values, the settings are the same as you have configured originally. Click next until finished. | ||
- | - Click send settings and include the Assistants. Note: the system will momentarily switch off! | + | - Click __S__end |
- All done. | - All done. | ||
assistants/how_to_update_an_assistant.txt · Last modified: 2019-01-22 10:16 by 127.0.0.1
