assistants:ess-assistant
| Next revision | Previous revision | ||
| assistants:ess-assistant [2016-11-30 10:08] – created mvader | assistants:ess-assistant [2019-01-22 09:44] (current) – external edit 127.0.0.1 | ||
| Line 1: | Line 1: | ||
| - | ====== ESS Assistant | + | ====== ESS Assistant ====== |
| - | to be completed. | + | The ESS Assistant is part of ESS. For more information see here: |
| - | it is basically equal to the Hub-4 Assistant, but then with a few additions: | + | [[ess:start|]] |
| - | * Power from an MPPT can now not only be used to power AC loads, but also be fed-in to the utility | ||
| - | * and more | ||
| - | See the draft blog: | ||
| - | https:// | ||
assistants/ess-assistant.1480500535.txt.gz · Last modified: by mvader
