assistants:ess-assistant
assistants:ess-assistant [2016-11-30 11:12] – mvader | assistants:ess-assistant [2019-01-22 10:44] (current) – external edit 127.0.0.1 | ||
- | ====== ESS Assistant | + | ====== ESS Assistant ====== |
- | to be completed. | + | The ESS Assistant is part of ESS. For more information see here: |
- | it is basically equal to the [[system_integration:hub4_grid_parallel|Hub-4 Assistant]], but then with a few additions: | + | [[ess:start|]] |
- | * Power from an MPPT can now not only be used to power AC loads, but also be fed-in to the utility | ||
- | * and more | ||
- | See the draft blog: | ||
- | https:// |
assistants/ess-assistant.txt · Last modified: 2019-01-22 10:44 by 127.0.0.1
