ac_current_sensor:start
ac_current_sensor:start [2019-01-22 10:16] – external edit 127.0.0.1ac_current_sensor:start [2019-08-15 12:40] (current) – replace venus-device with GX device guy_stewart
Line 5: Line 5:
 ==== Introduction ==== ==== Introduction ====
-Use the AC Current sensor to measure and visualise the solar production of a PV Inverter. The measurements will be visible on the [[venus-os:start|Venus-device]] and on the [[https://vrm.victronenergy.com|VRM Portal]].+Use the AC Current sensor to measure and visualise the solar production of a PV Inverter. The measurements will be visible on the [[venus-os:start|GX device]] and on the [[https://vrm.victronenergy.com|VRM Portal]].
 The sensor is a simple external current sensor, which measures AC Current. Together with the voltage measurements is calculated into Apparent Power (VA) and Energy (kWh). The sensor can be wired to either the AUX input or the Temperature-input of Multi and Quattro inverter/chargers. The sensor is a simple external current sensor, which measures AC Current. Together with the voltage measurements is calculated into Apparent Power (VA) and Energy (kWh). The sensor can be wired to either the AUX input or the Temperature-input of Multi and Quattro inverter/chargers.
Line 45: Line 45:
   - Then use the VEConfigure3 to add and configure the 'AC Current sensor’ assistant.   - Then use the VEConfigure3 to add and configure the 'AC Current sensor’ assistant.
   - Parallel and three-phase systems: add the assistant to each Multi or Quattro that has an AC Current sensor connected to it.   - Parallel and three-phase systems: add the assistant to each Multi or Quattro that has an AC Current sensor connected to it.
-  - Whilst the minimum required firmware in the [[venus-os:start|Venus-device]] is v1.30, we require running on a more recent version. +  - Whilst the minimum required firmware in the [[venus-os:start|GX device]] is v1.30, we require running on a more recent version.
-  - Select the correct profile on the [[venus-os:start|Venus-device]]: Settings -> System setup.+  - Select the correct profile on the [[venus-os:start|GX device]]: Settings -> System setup.
 ==== Compatibility list ==== ==== Compatibility list ====
ac_current_sensor/start.txt · Last modified: 2019-08-15 12:40 by guy_stewart
