Both sides previous revision Previous revision | Last revision Both sides next revision | ||
ac_coupling:start [2020-09-03 10:56] guy_stewart removed accubank? |
ac_coupling:start [2021-01-19 11:10] guystewart [4 Requirement of adding DC-Coupling - MPPT Solar Chargers] |
Line 71: | Line 71: | ||
- | 1 kWp installed PV power requires approximately 5kWh of battery: | + | 1 kWp installed PV power requires approximately 5kWh of lead acid battery: |
* 100 Ah at 48 Vdc | * 100 Ah at 48 Vdc | ||
* 200 Ah at 24 Vdc | * 200 Ah at 24 Vdc | ||
* 400 Ah at 12 Vdc | * 400 Ah at 12 Vdc | ||
+ | Each additional 1 kWp of AC PV will require an additional proportional 5 kWh increase in lead acid battery storage. | ||
- | 1,5 kWp installed PV power requires: | + | 1,5 kWp installed |
+ | Each additional 1.5 kWp of AC PV will require an additional proportional 4.8 kWh increase in battery storage. | ||
===== 4 Requirement of adding DC-Coupling - MPPT Solar Chargers ===== | ===== 4 Requirement of adding DC-Coupling - MPPT Solar Chargers ===== | ||
Line 89: | Line 91: | ||
Reason: recover from deadlock situation of AC-Coupling only situation. | Reason: recover from deadlock situation of AC-Coupling only situation. | ||
+ | There is no Factor 1.0 limit that applies for DC coupled PV through a Victron MPPT. Nor is there a specific minimum amount of battery storage capacity, though please follow battery manufacture specifications for maximum charge rates. A rule of thumb is C10 (10% of Ah capacity in A) for lead acid batteries, and C2 (50% of Ah capacity in A) for lithium batteries. | ||
===== 5 Software configuration ===== | ===== 5 Software configuration ===== |
