ac_coupling:fronius
ac_coupling:fronius [2020-11-26 02:24] – [2.5 Zero Feed-in] guy_stewart | ac_coupling:fronius [2023-11-30 07:13] (current) – [Q6 What do I do if my Fronius PV-inverter i guy_stewart | ||
This document describes how to setup Energy-storage, | This document describes how to setup Energy-storage, | ||
- | Victron GX Devices, eg [[https:// | + | Victron GX Devices, eg [[https:// |
Line 9: | Line 9: | ||
- | For Fronius information on the same subject, see their [[http:// | + | For Fronius information on the same subject, see their [[https:// |
A Victron & Fronius training webinar video is available to [[https:// | A Victron & Fronius training webinar video is available to [[https:// | ||
Line 81: | Line 81: | ||
====== 2. GX Devices & Fronius PV Inverters ====== | ====== 2. GX Devices & Fronius PV Inverters ====== | ||
- | By connecting a Fronius PV Inverter and GX device (eg [[https:// | + | By connecting a Fronius PV Inverter and GX device (eg Cerbo GX) together you will be able to: |
- See Fronius information on the GX Device. | - See Fronius information on the GX Device. | ||
- Monitor the Fronius on the VRM Portal. | - Monitor the Fronius on the VRM Portal. | ||
Line 97: | Line 97: | ||
| Fronius IG Plus (*) | Purchase and install the [[http:// | | Fronius IG Plus (*) | Purchase and install the [[http:// | ||
| Fronius Agilo | Purchase and install the [[http:// | | Fronius Agilo | Purchase and install the [[http:// | ||
+ | | Fronius GEN24 | See here for [[https:// | ||
(*) The Fronius Zero feed-in feature - which is part of an Energy Storage System [[ess: | (*) The Fronius Zero feed-in feature - which is part of an Energy Storage System [[ess: | ||
Line 147: | Line 148: | ||
If you would like to connect the Fronius to be able to use the internet connection of your Local network, you have to set Gateway and DNS IP addresses on the Fronius as well. They should be exactly the same as in the Settings --> Ethernet of the GX Device. | If you would like to connect the Fronius to be able to use the internet connection of your Local network, you have to set Gateway and DNS IP addresses on the Fronius as well. They should be exactly the same as in the Settings --> Ethernet of the GX Device. | ||
+ | === 2.2.1.4 special procedure for GEN24 model === | ||
+ | In Fronius GEN24 devices with software version 1.14 or higher, the Solar API interface is not activated by default and must be activated if required (e.g. integration of a GX device). | ||
+ | The setting for this can be found on the user interface of the Fronius inverter under " | ||
+ | For GEN24, there is no physical toggle switch required (as there is with other models). | ||
+ | Victron and Fronius have made no tests, nor make any claims about the performance of this integration. | ||
+ | If light flickering issues occur, please contact your Fronius dealer. | ||
==== 2.2.2 Adding Fronius to the GX Device ==== | ==== 2.2.2 Adding Fronius to the GX Device ==== | ||
Line 221: | Line 228: | ||
===== 2.5 Zero Feed-in ===== | ===== 2.5 Zero Feed-in ===== | ||
- | It is possible to make a Zero feed-in system with Victron & Fronius. The Venus device will the control the Fronius output power. See the [[https:// | + | It is possible to make a Zero feed-in system with Victron & Fronius. The Venus device will the control the Fronius output power. See the [[https:// |
Line 258: | Line 264: | ||
To update earlier and/or already installed PV Inverters, contact Fronius Tech Support for the file. The required file is fro29130.upd. Which works for all snap-inverter models (Primo, Symo and Eco). There is no, and will be no, fix available for Fronius Galvos. | To update earlier and/or already installed PV Inverters, contact Fronius Tech Support for the file. The required file is fro29130.upd. Which works for all snap-inverter models (Primo, Symo and Eco). There is no, and will be no, fix available for Fronius Galvos. | ||
- | ==== Q6 What do I do if my Fronius PV-inverter is detected as Unknown PV-inverter | + | ==== Q6 What do I do if my Fronius PV-inverter is detected as Unknown PV-inverter, or Multiphase, or cannot be configured as 3-phase? ==== |
Later Fronius PV-inverters support both the Fronius SolarAPI- as well as the industry standard SunSpec protocol. When SunSpec is not available the GX device cannot properly detect the properties of the PV-inverter unless it is one of a fixed list of known older models. Newer PV-inverters will then show up as Unknown, and you will not be able to configure them as 3-phase. | Later Fronius PV-inverters support both the Fronius SolarAPI- as well as the industry standard SunSpec protocol. When SunSpec is not available the GX device cannot properly detect the properties of the PV-inverter unless it is one of a fixed list of known older models. Newer PV-inverters will then show up as Unknown, and you will not be able to configure them as 3-phase. | ||
ac_coupling/fronius.1606353896.txt.gz · Last modified: 2020-11-26 02:24 by guy_stewart
