ac_coupling:fronius
ac_coupling:fronius [2016-12-15 13:11] – [Frequency shifting] mvader | ac_coupling:fronius [2023-11-30 07:13] (current) – [Q6 What do I do if my Fronius PV-inverter i guy_stewart | ||
Line 9: | Line 9: | ||
- | ===== Frequency shifting ===== | + | For Fronius information on the same subject, see their [[https:// |
+ | {{youtube> | ||
Line 16: | Line 21: | ||
* For on-grid / energy-storage systems, load the Multi or Quattro with the ESS Assistant. Read information about ESS in the [[ess: | * For on-grid / energy-storage systems, load the Multi or Quattro with the ESS Assistant. Read information about ESS in the [[ess: | ||
- | For new systems the Symo and Eco inverters are recommended for 3~ applications. The Primo inverters are recommended for 1~ applications. Please note that all these inverters are transformerless and therefore PV-Modules that require pole-grounding (on the Plus or Minus pole) cannot be connected. | + | For new systems the Fronius |
- | The use of Fronius Galvo inverters is not recommended anymore for new applications - the Fronius Primo is the best substitute and offers higher efficiency, wider DC voltage range, two MPP trackers | + | The use of Fronius Galvo inverters is not recommended anymore for new applications - the Fronius Primo is the best substitute and offers higher efficiency, wider DC voltage range and two MPP trackers. |
[[http:// | [[http:// | ||
- | ===== Setting up the Fronius with Setup MG50/MG60 ===== | + | ===== 1.3 Setting up the Fronius with Setup MG50/MG60 ===== |
Line 44: | Line 56: | ||
Line 51: | Line 63: | ||
- [[ess: | - [[ess: | ||
- | - Note that it is not necessary to change the default settings in the Assistant. \\ {{: | + | - Note that it is not necessary to change the default settings in the Assistant. \\ {{: |
- | Table for settings for 50Hz and 60Hz frequency | + | Table with general suggested |
| Start| 50.2 | 60.2|Hz| | | Start| 50.2 | 60.2|Hz| | ||
+ | Note that although the MG50 for instance has a higher start frequency of 51Hz, there is no real drawback using the proposed value of 50.2Hz. The system will just increase the frequency until the PV inverter regulation kicks in. The value of 50.2Hz will work with a broader range of PV inverters/ | ||
More information on adding Assistants is [[assistants: | More information on adding Assistants is [[assistants: | ||
- | ===== Remote system monitoring ===== | ||
- | The Victron system can be monitored through Victron VRM Portal if a [[https:// | ||
- | The Fronius PV inverter data can be [[ccgx: | ||
- | So the VRM portal is the recommended monitoring platform also for AC-coupled installations. | ||
- | However, also Fronius offers an equivalent monitoring solution. The Fronius portal is called Fronius Solar.web. The PV system data can be transfered to the portal if the inverter is equipped with a Datamanager 1.0 or Datamanager 2.0. | ||
- | The usage of both portals in parallel is possible. | + | ====== 2. GX Devices & Fronius PV Inverters ====== |
- | A video instruction how to set up the Datamanager 2.0 + Solar.web can be found [[https:// | + | By connecting a Fronius PV Inverter and GX device (eg Cerbo GX) together you will be able to: |
+ | - Allow the Victron system to control the Fronius output power, Zero feed-in. See the [[ess:design-installation-manual|ESS manual]], chapter 2.1.3 Fronius Zero feed-in for details. | ||
- | ===== Frequently asked questions ===== | + | This document describes how to setup the monitoring functions. |
- | === Why doesn' | + | ===== 2.1 Requirements ===== |
+ | | Fronius GEN24 | See here for [[https:// | ||
+ | === 2.2.1.4 special procedure for GEN24 model === | ||
+ | In Fronius GEN24 devices with software version 1.14 or higher, the Solar API interface is not activated by default and must be activated if required (e.g. integration of a GX device). | ||
+ | The setting for this can be found on the user interface of the Fronius inverter under " | ||
+ | For GEN24, there is no physical toggle switch required (as there is with other models). | ||
+ | Victron and Fronius have made no tests, nor make any claims about the performance of this integration. | ||
+ | If light flickering issues occur, please contact your Fronius dealer. | ||
+ | 5. Configure the // | ||
+ | 7. Done! | ||
+ | ^ State ^ Meaning ^ | ||
+ | It is possible to make a Zero feed-in system with Victron & Fronius. The Venus device will the control the Fronius output power. See the [[https:// | ||
+ | ====== 3. Frequently Asked Questions ====== | ||
+ | ==== Q1 Why doesn' | ||
+ | See [[: | ||
+ | ==== Q6 What do I do if my Fronius PV-inverter is detected as Unknown PV-inverter, | ||
+ | Later Fronius PV-inverters support both the Fronius SolarAPI- as well as the industry standard SunSpec protocol. When SunSpec is not available the GX device cannot properly detect the properties of the PV-inverter unless it is one of a fixed list of known older models. Newer PV-inverters will then show up as Unknown, and you will not be able to configure them as 3-phase. | ||
+ | The solution is to configure SunSpec support on the PV-inverter. | ||
+ | * Log into the Fronius web interface. | ||
+ | * Go to the Modbus tab | ||
+ | * Set Data export via Modbus to tcp. | ||
+ | * set Sunspec Model Type to int + SF | ||
ac_coupling/fronius.1481803910.txt.gz · Last modified: 2016-12-15 13:11 by mvader
