ac_coupling:fronius
ac_coupling:fronius [2020-11-26 02:24] – [2.5 Zero Feed-in] guy_stewart | ac_coupling:fronius [2023-03-13 03:52] – [2.1 Requirements] guy_stewart | ||
This document describes how to setup Energy-storage, | This document describes how to setup Energy-storage, | ||
- | Victron GX Devices, eg [[https:// | + | Victron GX Devices, eg [[https:// |
Line 81: | Line 81: | ||
====== 2. GX Devices & Fronius PV Inverters ====== | ====== 2. GX Devices & Fronius PV Inverters ====== | ||
- | By connecting a Fronius PV Inverter and GX device (eg [[https:// | + | By connecting a Fronius PV Inverter and GX device (eg Cerbo GX) together you will be able to: |
- See Fronius information on the GX Device. | - See Fronius information on the GX Device. | ||
- Monitor the Fronius on the VRM Portal. | - Monitor the Fronius on the VRM Portal. | ||
Line 97: | Line 97: | ||
| Fronius IG Plus (*) | Purchase and install the [[http:// | | Fronius IG Plus (*) | Purchase and install the [[http:// | ||
| Fronius Agilo | Purchase and install the [[http:// | | Fronius Agilo | Purchase and install the [[http:// | ||
+ | | Fronius GEN24 | See here for [[https:// | ||
(*) The Fronius Zero feed-in feature - which is part of an Energy Storage System [[ess: | (*) The Fronius Zero feed-in feature - which is part of an Energy Storage System [[ess: | ||
Line 147: | Line 148: | ||
If you would like to connect the Fronius to be able to use the internet connection of your Local network, you have to set Gateway and DNS IP addresses on the Fronius as well. They should be exactly the same as in the Settings --> Ethernet of the GX Device. | If you would like to connect the Fronius to be able to use the internet connection of your Local network, you have to set Gateway and DNS IP addresses on the Fronius as well. They should be exactly the same as in the Settings --> Ethernet of the GX Device. | ||
+ | === 2.2.1.4 special procedure for GEN24 model === | ||
+ | In Fronius GEN24 devices with software version 1.14 or higher, the Solar API interface is not activated by default and must be activated if required (e.g. integration of a GX device). | ||
+ | The setting for this can be found on the user interface of the Fronius inverter under " | ||
+ | For GEN24, there is no physical toggle switch required (as there is with other models). | ||
+ | Victron and Fronius have made no tests, nor make any claims about the performance of this integration. | ||
+ | If light flickering issues occur, please contact your Fronius dealer. | ||
==== 2.2.2 Adding Fronius to the GX Device ==== | ==== 2.2.2 Adding Fronius to the GX Device ==== | ||
