ac_coupling:fronius
Previous revisionNext revision | |||
— | ac_coupling:fronius [2020-11-26 02:24] – [2.5 Zero Feed-in] guy_stewart | ||
+ | ====== AC-coupled PV with Fronius PV Inverters ====== | ||
+ | This document describes how to setup Energy-storage, | ||
+ | Victron GX Devices, eg [[https:// | ||
+ | For Fronius information on the same subject, see their [[http:// | ||
+ | {{youtube> | ||
+ | To make sure that the Fronius PV inverter works well with Victron inverter/ | ||
+ | * The Fronius PV Inverter must be set to Setup MG, short for Micro-Grid. | ||
+ | * For off-grid systems, load the Multi or Quattro with the PV Inverter support Assistant | ||
+ | And the [[ac_coupling: | ||
+ | ===== 1.2 Fronius / Victron specifics ===== | ||
+ | This is a very easy setup. The Fronius Setup Microgrid has been developed in close cooperation with Victron. During commissioning, | ||
+ | **Compatible ROW inverters** (for " | ||
+ | * Fronius Primo (1~, 3 kW up to 8.2 kW) -> Software // | ||
+ | * Fronius Symo (3~, 3 kW up to 20 kW) -> Software // | ||
+ | * Fronius Eco (3~, 25 kW or 27 kW) -> Software // | ||
+ | * Fronius Agilo (3~, 75 kW up to 100 kW) -> Software // | ||
+ | * Fronius IG Plus V (1~, 2~, 3~, 2.5 kW up to 12 kW) -> from //IGF 5.0.66// on with settings according to the Victron recommendations | ||
+ | For new systems the Fronius Symo and Fronius Eco inverters are recommended for 3~ applications. The Fronius Primo inverters are recommended for 1~ applications. Please note that all these inverters are transformerless and therefore PV-Modules that require pole-grounding (on the Plus or Minus pole) cannot be connected. | ||
+ | The use of Fronius Galvo inverters is not recommended anymore for new applications - the Fronius Primo is the best substitute and offers higher efficiency, wider DC voltage range and two MPP trackers. | ||
+ | When setting up a system, always update both the Fronius and the Victron devices to their latest firmware versions. For the latest Fronius firmware and information how to update use this link: | ||
+ | [[http:// | ||
+ | ===== 1.3 Setting up the Fronius with Setup MG50/MG60 ===== | ||
+ | When not pre-ordered with a MicroGrid setup, follow these steps: | ||
+ | - Make sure that the Fronius PV inverter is updated to at least the firmware version mentioned above. See Inverter list above. | ||
+ | - After making the inverter operational according to the manual, select the language and after this the country specific setup. | ||
+ | - Here choose MG50 or MG60 depending on the system frequency. | ||
+ | - Ready to start up. | ||
+ | ===== 1.4 Setting up the Victron Multi or Quattro ===== | ||
+ | - After connecting the MultiPlus or Quattro with the battery, you can now connect a computer through the VE.Bus (in combination with the Victron interface MK2USB) to configure the system with the latest version of the software VE.Configure. | ||
+ | - Go to the tab Assistants: \\ {{: | ||
+ | - Add one of the Assistants that regulate output frequency: | ||
+ | - [[ess: | ||
+ | - PV Inverter support | ||
+ | - Note that it is not necessary to change the default settings in the Assistant. \\ {{: | ||
+ | - Complete the rest of the Assistant and write the new settings to the MultiPlus or Quattro. | ||
+ | Table with general suggested settings for 50Hz and 60Hz frequency | ||
+ | | ** State ** | ** 50Hz ** | ** 60Hz ** |. | | ||
+ | | Start| 50.2 | 60.2|Hz| | ||
+ | Note that although the MG50 for instance has a higher start frequency of 51Hz, there is no real drawback using the proposed value of 50.2Hz. The system will just increase the frequency until the PV inverter regulation kicks in. The value of 50.2Hz will work with a broader range of PV inverters/ | ||
+ | More information on adding Assistants is [[assistants: | ||
+ | ====== 2. GX Devices & Fronius PV Inverters ====== | ||
+ | By connecting a Fronius PV Inverter and GX device (eg [[https:// | ||
+ | This document describes how to setup the monitoring functions. | ||
+ | ===== 2.1 Requirements ===== | ||
+ | As an example: 192.168.10.1-254 for LAN IP's and 192.168.11.1-254 for WiFi IP's. | ||
+ | 3. The GX Device will automatically scan for PV-inverters on the local network if no PV-inverters were found previously or if a previously-found PV-inverter cannot be contacted. This will happen if the IP address of the PV-inverter changes. To prevent automatic scanning, disable //Automatic scanning//. | ||
+ | 5. Configure the // | ||
+ | 7. Done! | ||
+ | ^ State ^ Meaning ^ | ||
+ | It is possible to make a Zero feed-in system with Victron & Fronius. The Venus device will the control the Fronius output power. See the [[https:// | ||
+ | ====== 3. Frequently Asked Questions ====== | ||
+ | ==== Q1 Why doesn' | ||
+ | The first two frequencies do not need to be the same since the Multi actively regulates. | ||
+ | ==== Q2 I have an Fronius IG inverter (not Plus), can that work? ==== | ||
+ | No, the IG inverters cannot be made to work in a MicroGrid system. The appropriate substitute for an IG 30 is the GALVO 2.5-1 or an IG Plus 25V-1 (depending on the desired DC voltage range). | ||
+ | See [[: | ||
+ | ==== Q6 What do I do if my Fronius PV-inverter is detected as Unknown PV-inverter and cannot be configured as 3-phase? ==== | ||
+ | Later Fronius PV-inverters support both the Fronius SolarAPI- as well as the industry standard SunSpec protocol. When SunSpec is not available the GX device cannot properly detect the properties of the PV-inverter unless it is one of a fixed list of known older models. Newer PV-inverters will then show up as Unknown, and you will not be able to configure them as 3-phase. | ||
+ | The solution is to configure SunSpec support on the PV-inverter. | ||
+ | * Log into the Fronius web interface. | ||
+ | * Go to the Modbus tab | ||
+ | * Set Data export via Modbus to tcp. | ||
+ | * set Sunspec Model Type to int + SF | ||
+ | ~~DISQUS~~ | ||
