ac_coupling:fronius
ac_coupling:fronius [2019-08-06 08:53] – [Zero Feed-in] bob | ac_coupling:fronius [2020-04-30 13:39] – external edit 127.0.0.1 | ||
Line 9: | Line 9: | ||
- | ===== Frequency shifting ===== | + | For Fronius information on the same subject, see their [[http:// |
+ | {{youtube> | ||
Line 18: | Line 23: | ||
And the [[ac_coupling: | And the [[ac_coupling: | ||
* Fronius Primo (1~, 3 kW up to 8.2 kW) -> Software // | * Fronius Primo (1~, 3 kW up to 8.2 kW) -> Software // | ||
* Fronius Symo (3~, 3 kW up to 20 kW) -> Software // | * Fronius Symo (3~, 3 kW up to 20 kW) -> Software // | ||
Line 29: | Line 34: | ||
- | For new systems the Symo and Eco inverters are recommended for 3~ applications. The Primo inverters are recommended for 1~ applications. Please note that all these inverters are transformerless and therefore PV-Modules that require pole-grounding (on the Plus or Minus pole) cannot be connected. | + | For new systems the Fronius |
- | The use of Fronius Galvo inverters is not recommended anymore for new applications - the Fronius Primo is the best substitute and offers higher efficiency, wider DC voltage range, two MPP trackers | + | The use of Fronius Galvo inverters is not recommended anymore for new applications - the Fronius Primo is the best substitute and offers higher efficiency, wider DC voltage range and two MPP trackers. |
[[http:// | [[http:// | ||
- | ===== Setting up the Fronius with Setup MG50/MG60 ===== | + | ===== 1.3 Setting up the Fronius with Setup MG50/MG60 ===== |
Line 44: | Line 56: | ||
Line 51: | Line 63: | ||
- [[ess: | - [[ess: | ||
- | - Note that it is not necessary to change the default settings in the Assistant. \\ {{: | + | - Note that it is not necessary to change the default settings in the Assistant. \\ {{: |
- | Table for settings for 50Hz and 60Hz frequency | + | Table with general suggested |
- | | Start| | + | | Start| |
+ | Note that although the MG50 for instance has a higher start frequency of 51Hz, there is no real drawback using the proposed value of 50.2Hz. The system will just increase the frequency until the PV inverter regulation kicks in. The value of 50.2Hz will work with a broader range of PV inverters/ | ||
More information on adding Assistants is [[assistants: | More information on adding Assistants is [[assistants: | ||
- | ===== Remote system monitoring ===== | ||
- | The Victron system can be monitored through Victron VRM Portal if a [[https:// | ||
- | The Fronius PV inverter data can be [[ccgx: | ||
- | So the VRM portal is the recommended monitoring platform also for AC-coupled installations. | ||
- | However, also Fronius offers an equivalent monitoring solution. The Fronius portal is called Fronius Solar.web. The PV system data can be transfered to the portal if the inverter is equipped with a Datamanager 1.0 or Datamanager 2.0. | ||
- | The usage of both portals in parallel is possible. | + | ====== 2. GX Devices & Fronius PV Inverters ====== |
- | A video instruction how to set up the Datamanager 2.0 + Solar.web can be found [[https://youtu.be/u_DX7PmHPXQ|here]]. | + | By connecting a Fronius PV Inverter and GX device (eg [[https://www.victronenergy.com/ |
- | ===== Zero Feed-in ===== | + | This document describes how to setup the monitoring functions. |
+ | ===== 2.1 Requirements ===== | ||
+ | 5. Configure the // | ||
+ | 7. Done! | ||
+ | ^ State ^ Meaning ^ | ||
It is possible to make a Zero feed-in system with Victron & Fronius. The Venus device will the control the Fronius output power. See the [[ess: | It is possible to make a Zero feed-in system with Victron & Fronius. The Venus device will the control the Fronius output power. See the [[ess: | ||
- | ===== Frequently Asked Questions ===== | + | |
+ | ====== 3. Frequently Asked Questions | ||
==== Q1 Why doesn' | ==== Q1 Why doesn' | ||
Line 112: | Line 261: | ||
