ac_coupling:fronius
ac_coupling:fronius [2019-08-06 08:53] – [Zero Feed-in] bob | ac_coupling:fronius [2020-03-19 15:37] – guy_stewart | ||
Line 9: | Line 9: | ||
- | ===== Frequency shifting ===== | + | For Fronius information on the same subject, see their [[http:// |
+ | {{youtube> | ||
Line 18: | Line 23: | ||
And the [[ac_coupling: | And the [[ac_coupling: | ||
* Fronius Primo (1~, 3 kW up to 8.2 kW) -> Software // | * Fronius Primo (1~, 3 kW up to 8.2 kW) -> Software // | ||
* Fronius Symo (3~, 3 kW up to 20 kW) -> Software // | * Fronius Symo (3~, 3 kW up to 20 kW) -> Software // | ||
Line 29: | Line 34: | ||
- | For new systems the Symo and Eco inverters are recommended for 3~ applications. The Primo inverters are recommended for 1~ applications. Please note that all these inverters are transformerless and therefore PV-Modules that require pole-grounding (on the Plus or Minus pole) cannot be connected. | + | For new systems the Fronius |
- | The use of Fronius Galvo inverters is not recommended anymore for new applications - the Fronius Primo is the best substitute and offers higher efficiency, wider DC voltage range, two MPP trackers | + | The use of Fronius Galvo inverters is not recommended anymore for new applications - the Fronius Primo is the best substitute and offers higher efficiency, wider DC voltage range and two MPP trackers. |
[[http:// | [[http:// | ||
- | ===== Setting up the Fronius with Setup MG50/MG60 ===== | + | ===== 1.3 Setting up the Fronius with Setup MG50/MG60 ===== |
Line 44: | Line 56: | ||
Line 63: | Line 75: | ||
More information on adding Assistants is [[assistants: | More information on adding Assistants is [[assistants: | ||
- | ===== Remote system monitoring ===== | ||
- | The Victron system can be monitored through Victron VRM Portal if a [[https:// | ||
- | The Fronius PV inverter data can be [[ccgx: | ||
- | So the VRM portal is the recommended monitoring platform also for AC-coupled installations. | ||
- | However, also Fronius offers an equivalent monitoring solution. The Fronius portal is called Fronius Solar.web. The PV system data can be transfered to the portal if the inverter is equipped with a Datamanager 1.0 or Datamanager 2.0. | ||
- | The usage of both portals in parallel is possible. | + | ====== 2. GX Devices & Fronius PV Inverters ====== |
- | A video instruction how to set up the Datamanager 2.0 + Solar.web can be found [[https://youtu.be/u_DX7PmHPXQ|here]]. | + | By connecting a Fronius PV Inverter and GX device (eg [[https://www.victronenergy.com/ |
- | ===== Zero Feed-in ===== | + | This document describes how to setup the monitoring functions. |
+ | ===== 2.1 Requirements ===== | ||
+ | 5. Configure the // | ||
+ | 7. Done! | ||
+ | ^ State ^ Meaning ^ | ||
It is possible to make a Zero feed-in system with Victron & Fronius. The Venus device will the control the Fronius output power. See the [[ess: | It is possible to make a Zero feed-in system with Victron & Fronius. The Venus device will the control the Fronius output power. See the [[ess: | ||
- | ===== Frequently Asked Questions ===== | + | |
+ | ====== 3. Frequently Asked Questions | ||
==== Q1 Why doesn' | ==== Q1 Why doesn' | ||
Line 112: | Line 259: | ||
