ac_coupling:fronius
ac_coupling:fronius [2019-08-06 08:53] – [Zero Feed-in] bob | ac_coupling:fronius [2019-09-18 08:10] – [Fronius / Victron specifics] schwarzlmueller.martin | ||
Line 22: | Line 22: | ||
* Fronius Primo (1~, 3 kW up to 8.2 kW) -> Software // | * Fronius Primo (1~, 3 kW up to 8.2 kW) -> Software // | ||
* Fronius Symo (3~, 3 kW up to 20 kW) -> Software // | * Fronius Symo (3~, 3 kW up to 20 kW) -> Software // | ||
Line 29: | Line 29: | ||
- | For new systems the Symo and Eco inverters are recommended for 3~ applications. The Primo inverters are recommended for 1~ applications. Please note that all these inverters are transformerless and therefore PV-Modules that require pole-grounding (on the Plus or Minus pole) cannot be connected. | + | For new systems the Fronius |
- | The use of Fronius Galvo inverters is not recommended anymore for new applications - the Fronius Primo is the best substitute and offers higher efficiency, wider DC voltage range, two MPP trackers | + | The use of Fronius Galvo inverters is not recommended anymore for new applications - the Fronius Primo is the best substitute and offers higher efficiency, wider DC voltage range and two MPP trackers. |
When setting up a system, always update both the Fronius and the Victron devices to their latest firmware versions. For the latest Fronius firmware and information how to update use this link: | When setting up a system, always update both the Fronius and the Victron devices to their latest firmware versions. For the latest Fronius firmware and information how to update use this link: |
