ac_coupling:fronius
ac_coupling:fronius [2019-01-21 05:56] – [Frequency shifting] guy_stewart | ac_coupling:fronius [2020-01-19 15:09] – external edit 127.0.0.1 | ||
Line 22: | Line 22: | ||
* Fronius Primo (1~, 3 kW up to 8.2 kW) -> Software // | * Fronius Primo (1~, 3 kW up to 8.2 kW) -> Software // | ||
* Fronius Symo (3~, 3 kW up to 20 kW) -> Software // | * Fronius Symo (3~, 3 kW up to 20 kW) -> Software // | ||
Line 29: | Line 29: | ||
- | For new systems the Symo and Eco inverters are recommended for 3~ applications. The Primo inverters are recommended for 1~ applications. Please note that all these inverters are transformerless and therefore PV-Modules that require pole-grounding (on the Plus or Minus pole) cannot be connected. | + | For new systems the Fronius |
- | The use of Fronius Galvo inverters is not recommended anymore for new applications - the Fronius Primo is the best substitute and offers higher efficiency, wider DC voltage range, two MPP trackers | + | The use of Fronius Galvo inverters is not recommended anymore for new applications - the Fronius Primo is the best substitute and offers higher efficiency, wider DC voltage range and two MPP trackers. |
Line 77: | Line 84: | ||
===== Zero Feed-in ===== | ===== Zero Feed-in ===== | ||
- | It is possible to make a Zero feed-in system with Victron & Fronius. The Venus device will the control the Fronius output power. See the [[ess: | + | It is possible to make a Zero feed-in system with Victron & Fronius. The Venus device will the control the Fronius output power. See the [[ess: |
===== Frequently Asked Questions ===== | ===== Frequently Asked Questions ===== | ||
Line 91: | Line 98: | ||
==== Q4 Can I use the Fronius Smart Meter? ==== | ==== Q4 Can I use the Fronius Smart Meter? ==== | ||
- | No, when using a Fronius | + | That depends on the type of system and software configuration. |
+ | A Fronius | ||
+ | - when used for limiting export, | ||
- | Use any of the [[energy-meters: | ||
==== Q5 How can I get the Fronius firmware that improves flickering? ==== | ==== Q5 How can I get the Fronius firmware that improves flickering? ==== | ||
Line 106: | Line 119: | ||
