ac_coupling:fronius
ac_coupling:fronius [2017-12-03 11:07] – mvader | ac_coupling:fronius [2020-06-09 13:43] – [Q5 How can I get the Fronius firmware that improves flickering?] iburger | ||
Line 9: | Line 9: | ||
- | ===== Frequency shifting ===== | + | For Fronius information on the same subject, see their [[http:// |
+ | {{youtube> | ||
Line 16: | Line 21: | ||
* For on-grid / energy-storage systems, load the Multi or Quattro with the ESS Assistant. Read information about ESS in the [[ess: | * For on-grid / energy-storage systems, load the Multi or Quattro with the ESS Assistant. Read information about ESS in the [[ess: | ||
- | For new systems the Symo and Eco inverters are recommended for 3~ applications. The Primo inverters are recommended for 1~ applications. Please note that all these inverters are transformerless and therefore PV-Modules that require pole-grounding (on the Plus or Minus pole) cannot be connected. | + | For new systems the Fronius |
- | The use of Fronius Galvo inverters is not recommended anymore for new applications - the Fronius Primo is the best substitute and offers higher efficiency, wider DC voltage range, two MPP trackers | + | The use of Fronius Galvo inverters is not recommended anymore for new applications - the Fronius Primo is the best substitute and offers higher efficiency, wider DC voltage range and two MPP trackers. |
[[http:// | [[http:// | ||
- | ===== Setting up the Fronius with Setup MG50/MG60 ===== | + | ===== 1.3 Setting up the Fronius with Setup MG50/MG60 ===== |
Line 44: | Line 56: | ||
Line 51: | Line 63: | ||
- [[ess: | - [[ess: | ||
- | - Note that it is not necessary to change the default settings in the Assistant. \\ {{: | + | - Note that it is not necessary to change the default settings in the Assistant. \\ {{: |
- | Table for settings for 50Hz and 60Hz frequency | + | Table with general suggested |
| Start| 50.2 | 60.2|Hz| | | Start| 50.2 | 60.2|Hz| | ||
+ | Note that although the MG50 for instance has a higher start frequency of 51Hz, there is no real drawback using the proposed value of 50.2Hz. The system will just increase the frequency until the PV inverter regulation kicks in. The value of 50.2Hz will work with a broader range of PV inverters/ | ||
More information on adding Assistants is [[assistants: | More information on adding Assistants is [[assistants: | ||
- | ===== Remote system monitoring ===== | ||
- | The Victron system can be monitored through Victron VRM Portal if a [[https:// | ||
- | The Fronius PV inverter data can be [[ccgx: | ||
- | So the VRM portal is the recommended monitoring platform also for AC-coupled installations. | ||
- | However, also Fronius offers an equivalent monitoring solution. The Fronius portal is called Fronius Solar.web. The PV system data can be transfered to the portal if the inverter is equipped with a Datamanager 1.0 or Datamanager 2.0. | ||
- | The usage of both portals in parallel is possible. | + | ====== 2. GX Devices & Fronius PV Inverters ====== |
- | A video instruction how to set up the Datamanager 2.0 + Solar.web can be found [[https://youtu.be/u_DX7PmHPXQ|here]]. | + | By connecting a Fronius PV Inverter and GX device (eg [[https://www.victronenergy.com/ |
- | ===== Zero Feed-in ===== | + | This document describes how to setup the monitoring functions. |
- | It is possible to make a Zero feed-in system with Victron & Fronius. The Venus device will the control the Fronius | + | ===== 2.1 Requirements ===== |
- | ===== Frequently asked questions ===== | + | ^ Model ^ Required accessory ^ |
+ | | Fronius | ||
- | === Why doesn' | + | (*) The Fronius Zero feed-in feature - which is part of an Energy Storage System [[ess: |
+ | 5. Configure the // | ||
+ | 7. Done! | ||
+ | ^ State ^ Meaning ^ | ||
+ | ====== 3. Frequently Asked Questions ====== | ||
+ | ==== Q1 Why doesn' | ||
- | === The system is locked to 53Hz and does not drop down === | + | ==== Q3 The system is locked to 53 Hz and does not resume ==== |
- | Its locked to the upper limit because of a battery overvoltage. | + | See [[: |
- | The frequency will reset itself once the system | + | That depends on the type of system |
- | Above voltages are for a lithium battery. When configured for other battery types, the voltage needs to drop 5.2V below the configured float voltage. Unless that is configure to 56,8V or higher, then the battery voltage needs to drop below 51.6V for the system to switch back to bulk. | + | A Fronius Smart Meter can be used in these two situations: |
- | Alternatively, power cycle the system | + | - when used only for reporting to Solarweb |
- | To prevent this from happening again, check your configured float voltage: setting it lower will prevent | + | The Fronius Smart-Meter can not be used for the Fronius built-in export limiting feature when part of a Victron ESS system. Instead, use the Victron ESS Fronius Zero-feed in feature, see chapter 4.3.11, Fronius Zero Feed-in, in the [[ess: |
- | Note that all voltages are for 48V systems. For 24V divide all values by 2, and for 12V divide by four. | ||
- | === Can I use the Fronius | + | ==== Q5 How can I get the Fronius |
- | No, when using a Fronius | + | Fronius |
- | Use any of the [[energy-meters: | + | For Fronius PV inverters produced after 2018-week 16, contain |
+ | ==== Q6 What do I do if my Fronius PV-inverter is detected as Unknown PV-inverter and cannot be configured as 3-phase? ==== | ||
+ | Later Fronius PV-inverters support both the Fronius SolarAPI- as well as the industry standard SunSpec protocol. When SunSpec is not available the GX device cannot properly detect the properties of the PV-inverter unless it is one of a fixed list of known older models. Newer PV-inverters will then show up as Unknown, and you will not be able to configure them as 3-phase. | ||
+ | The solution is to configure SunSpec support on the PV-inverter. | ||
+ | * Log into the Fronius web interface. | ||
+ | * Go to the Modbus tab | ||
+ | * Set Data export via Modbus to tcp. | ||
+ | * set Sunspec Model Type to int + SF | ||
