ac_coupling:fronius
ac_coupling:fronius [2017-10-26 17:28] – mvader | ac_coupling:fronius [2019-07-01 13:24] – [Zero Feed-in] mvader | ||
Line 16: | Line 16: | ||
* For on-grid / energy-storage systems, load the Multi or Quattro with the ESS Assistant. Read information about ESS in the [[ess: | * For on-grid / energy-storage systems, load the Multi or Quattro with the ESS Assistant. Read information about ESS in the [[ess: | ||
Line 23: | Line 23: | ||
Line 57: | Line 57: | ||
Table for settings for 50Hz and 60Hz frequency | Table for settings for 50Hz and 60Hz frequency | ||
- | | Start| | + | | Start| |
Line 75: | Line 75: | ||
A video instruction how to set up the Datamanager 2.0 + Solar.web can be found [[https:// | A video instruction how to set up the Datamanager 2.0 + Solar.web can be found [[https:// | ||
- | ===== Frequently asked questions | + | ===== Zero Feed-in |
- | === Why doesn' | + | It is possible to make a Zero feed-in system with Victron & Fronius. The Venus device will the control the Fronius output power. See the [[ess: |
+ | ==== Q1 Why doesn' | ||
- | === The system is locked to 53Hz and does not drop down === | + | ==== Q3 The system is locked to 53 Hz and does not resume ==== |
- | Its locked to the upper limit because of a battery overvoltage. | + | See [[: |
- | The frequency will reset itself once the system | + | That depends on the type of system |
- | Above voltages are for a lithium battery. When configured for other battery types, the voltage needs to drop 5.2V below the configured float voltage. Unless that is configure to 56,8V or higher, then the battery voltage needs to drop below 51.6V for the system to switch back to bulk. | + | A Fronius Smart Meter can be used in these two situations: |
- | Alternatively, power cycle the system | + | - when used only for reporting to Solarweb |
- | To prevent this from happening again, check your configured float voltage: setting it lower will prevent | + | The Fronius Smart-Meter can not be used for the Fronius built-in export limiting feature when part of a Victron ESS system. Instead, use the Victron ESS Fronius Zero-feed in feature, see chapter 4.3.11, Fronius Zero Feed-in, in the [[ess: |
- | Note that all voltages are for 48V systems. For 24V divide | + | |
+ | ==== Q5 How can I get the Fronius firmware | ||
+ | To update earlier and/or already installed PV Inverters, contact Fronius Tech Support for the file. The required file is fro29130.upd. Which works for all snap-inverter models (Primo, Symo and Eco). There is no, and will be no, fix available | ||
