ac_coupling:fronius
ac_coupling:fronius [2017-10-26 17:28] – mvader | ac_coupling:fronius [2019-04-14 12:39] – external edit 127.0.0.1 | ||
Line 16: | Line 16: | ||
* For on-grid / energy-storage systems, load the Multi or Quattro with the ESS Assistant. Read information about ESS in the [[ess: | * For on-grid / energy-storage systems, load the Multi or Quattro with the ESS Assistant. Read information about ESS in the [[ess: | ||
Line 23: | Line 23: | ||
Line 57: | Line 57: | ||
Table for settings for 50Hz and 60Hz frequency | Table for settings for 50Hz and 60Hz frequency | ||
- | | Start| | + | | Start| |
Line 75: | Line 75: | ||
A video instruction how to set up the Datamanager 2.0 + Solar.web can be found [[https:// | A video instruction how to set up the Datamanager 2.0 + Solar.web can be found [[https:// | ||
- | ===== Frequently asked questions | + | ===== Zero Feed-in |
- | === Why doesn' | + | It is possible to make a Zero feed-in system with Victron & Fronius. The Venus device will the control the Fronius output power. See the [[ess: |
+ | ==== Q1 Why doesn' | ||
- | === The system is locked to 53Hz and does not drop down === | + | ==== Q3 The system is locked to 53 Hz and does not resume ==== |
- | Its locked to the upper limit because of a battery overvoltage. | + | See [[: |
- | The frequency will reset itself once the system | + | No, when using a Fronius PV Inverter in a Victron |
- | Above voltages are for a lithium battery. When configured for other battery types, | + | Use any of the [[energy-meters: |
- | Alternatively, | + | ==== Q5 How can I get the Fronius firmware that improves flickering? ==== |
- | To prevent this from happening again, check your configured float voltage: setting it lower will prevent the overvoltage condition from happening again. | + | Fronius has a special firmware available, on request, that fixes light flickering issues that occur on certain installations under certain circumstances. |
- | Note that all voltages are for 48V systems. For 24V divide | + | For Fronius PV inverters produced after 2018-week 16, contain the flicker-fix already straight from production. |
+ | To update earlier and/or already installed PV Inverters, contact Fronius Tech Support | ||
