ac_coupling:fronius
ac_coupling:fronius [2016-02-22 14:01] – martijncoster | ac_coupling:fronius [2019-09-18 08:10] – [Fronius / Victron specifics] schwarzlmueller.martin | ||
Line 4: | Line 4: | ||
The Victron system monitor, the [[https:// | The Victron system monitor, the [[https:// | ||
===== Frequency shifting ===== | ===== Frequency shifting ===== | ||
Line 9: | Line 13: | ||
- | This is a very easy setup. The Fronius Setup MG has been developed in close cooperation with Victron | + | This is a very easy setup. The Fronius Setup Microgrid |
- | * Fronius | + | |
- | Recommended for new systems | + | For new systems the Fronius |
- | When the PV modules need to be grounded, | + | The use of Fronius Galvo inverters |
+ | * Fronius | ||
[[http:// | [[http:// | ||
- | ===== Setting up the Fronius with MG 50/60 ===== | + | ===== Setting up the Fronius with Setup MG50/MG60 ===== |
Line 45: | Line 56: | ||
- Note that it is not necessary to change the default settings in the Assistant. \\ {{: | - Note that it is not necessary to change the default settings in the Assistant. \\ {{: | ||
Line 53: | Line 63: | ||
Table for settings for 50Hz and 60Hz frequency | Table for settings for 50Hz and 60Hz frequency | ||
- | | ** state ** | ** 50Hz ** | ** 60Hz ** |. | | + | | ** State ** | ** 50Hz ** | ** 60Hz ** |. | |
- | | Start| | + | | Start| |
- | More information on adding | + | More information on adding |
- | ===== Frequently asked questions ===== | + | |
- | === Why doesn' | + | ===== Remote system monitoring ===== |
+ | The Victron system can be monitored through Victron VRM Portal if a [[https:// | ||
+ | The Fronius PV inverter data can be [[ccgx: | ||
+ | So the VRM portal is the recommended monitoring platform also for AC-coupled installations. | ||
+ | However, also Fronius offers an equivalent monitoring solution. The Fronius portal is called Fronius Solar.web. The PV system data can be transfered to the portal if the inverter is equipped with a Datamanager 1.0 or Datamanager 2.0. | ||
+ | The usage of both portals in parallel is possible. | ||
+ | A video instruction how to set up the Datamanager 2.0 + Solar.web can be found [[https:// | ||
+ | ===== Zero Feed-in ===== | ||
+ | ==== Q1 Why doesn' | ||
+ | See [[: | ||
