ac_coupling:fronius
ac_coupling:fronius [2016-01-08 16:17] – ictbeheer | ac_coupling:fronius [2020-03-19 15:37] – guy_stewart | ||
- | ===== Frequency shifting ===== | + | {{: |
+ | For Fronius information on the same subject, see their [[http:// | ||
+ | {{youtube> | ||
- | This is a very easy setup. The Fronius Setup MG has been developed in close cooperation with Victron | + | This is a very easy setup. The Fronius Setup Microgrid |
- | * Fronius | + | |
- | Recommended for new systems | + | For new systems the Fronius |
- | When the PV modules need to be grounded, | + | The use of Fronius Galvo inverters |
+ | * Fronius | ||
[[http:// | [[http:// | ||
- | ===== Setting up the Fronius with MG 50/60 ===== | + | ===== 1.3 Setting up the Fronius with Setup MG50/MG60 ===== |
Line 40: | Line 56: | ||
- Note that it is not necessary to change the default settings in the Assistant. \\ {{: | - Note that it is not necessary to change the default settings in the Assistant. \\ {{: | ||
Line 52: | Line 67: | ||
- | More information on adding Assistans is [[assistants: | + | Table for settings for 50Hz and 60Hz frequency |
- | ===== Frequently asked questions ===== | + | | ** State ** | ** 50Hz ** | ** 60Hz ** |. | |
+ | | Start| 51.0 | 60.2|Hz| | ||
- | === Why doesn' | + | More information on adding Assistants is [[assistants: |
+ | ====== 2. GX Devices & Fronius PV Inverters ====== | ||
+ | By connecting a Fronius PV Inverter and GX device (eg [[https:// | ||
+ | This document describes how to setup the monitoring functions. | ||
+ | ===== 2.1 Requirements ===== | ||
+ | 5. Configure the // | ||
+ | 7. Done! | ||
+ | ^ State ^ Meaning ^ | ||
+ | ====== 3. Frequently Asked Questions ====== | ||
+ | ==== Q1 Why doesn' | ||
+ | See [[: | ||
