ac_coupling:fronius
ac_coupling:fronius [2016-01-05 10:31] – martijncoster | ac_coupling:fronius [2020-04-03 10:14] – [1.4 Setting up the Victron Multi or Quattro] pba | ||
- | ===== Frequency shifting ===== | + | {{: |
+ | For Fronius information on the same subject, see their [[http:// | ||
+ | {{youtube> | ||
- | This is a very easy setup. The Fronius Setup MG has been developed in close cooperation with Victron | + | This is a very easy setup. The Fronius Setup Microgrid |
- | * Fronius | + | |
- | Recommended for new systems | + | For new systems the Fronius |
- | When the PV modules need to be grounded, | + | The use of Fronius Galvo inverters |
+ | * Fronius | ||
[[http:// | [[http:// | ||
- | ===== Setting up the Fronius with MG 50/60 ===== | + | ===== 1.3 Setting up the Fronius with Setup MG50/MG60 ===== |
Line 40: | Line 56: | ||
- | - Note that it is not necessary to change the default settings in the Assistant. \\ {{: | + | - Note that it is not necessary to change the default settings in the Assistant. \\ {{: |
- | More information on adding Assistans is [[assistants: | + | Table with general suggested settings for 50Hz and 60Hz frequency |
- | ===== Frequently asked questions ===== | + | | ** State ** | ** 50Hz ** | ** 60Hz ** |. | |
+ | | Start| 50.2 | 60.2|Hz| | ||
- | === Why doesn' | + | Note that although the MG50 for instance has a higher start frequency of 51Hz, there is no real drawback using the proposed value of 50.2Hz. The system will just increase the frequency until the PV inverter regulation kicks in. The value of 50.2Hz will work with a broader range of PV inverters/ |
+ | More information on adding Assistants is [[assistants: | ||
+ | ====== 2. GX Devices & Fronius PV Inverters ====== | ||
+ | By connecting a Fronius PV Inverter and GX device (eg [[https:// | ||
+ | This document describes how to setup the monitoring functions. | ||
+ | ===== 2.1 Requirements ===== | ||
+ | 5. Configure the // | ||
+ | 7. Done! | ||
+ | ^ State ^ Meaning ^ | ||
+ | ====== 3. Frequently Asked Questions ====== | ||
+ | ==== Q1 Why doesn' | ||
+ | See [[: | ||
