ac_coupling:fronius
ac_coupling:fronius [2015-12-03 15:15] – [Setting up the Victron Multi or Quattro] mvader | ac_coupling:fronius [2020-06-09 13:43] – [Q5 How can I get the Fronius firmware that improves flickering?] iburger | ||
- | ===== Frequency shifting ===== | + | {{: |
+ | For Fronius information on the same subject, see their [[http:// | ||
+ | {{youtube> | ||
- | This is a very easy setup. The Fronius Setup MG has been developed in close cooperation with Victron | + | This is a very easy setup. The Fronius Setup Microgrid |
- | * Fronius | + | |
- | Recommended for new systems | + | For new systems the Fronius |
- | When the PV modules need to be grounded, | + | The use of Fronius Galvo inverters |
- | When setting | + | **Compatible UL inverters** (for "US type AC grid") are: |
+ | * Fronius | ||
- | ===== Setting up the Fronius with MG 50/60 ===== | + | For the UL inverters, some more Microgrid Setups are available (e.g. for connection with Neutral conductor or without). Also the UL inverters can be used in 60Hz as well as in 50Hz applications. More information can be found in the user manuals. |
+ | When setting up a system, always update both the Fronius and the Victron devices to their latest firmware versions. For the latest Fronius firmware and information how to update use this link: | ||
+ | [[http:// | ||
+ | ===== 1.3 Setting up the Fronius with Setup MG50/MG60 ===== | ||
Line 39: | Line 56: | ||
- | - Note that it is not necessary to change the default settings in the Assistant. \\ {{: | + | - Note that it is not necessary to change the default settings in the Assistant. \\ {{: |
- | More information on adding Assistans is [[assistants: | + | Table with general suggested settings for 50Hz and 60Hz frequency |
- | ===== Frequently asked questions ===== | + | | ** State ** | ** 50Hz ** | ** 60Hz ** |. | |
+ | | Start| 50.2 | 60.2|Hz| | ||
- | === Why doesn' | + | Note that although the MG50 for instance has a higher start frequency of 51Hz, there is no real drawback using the proposed value of 50.2Hz. The system will just increase the frequency until the PV inverter regulation kicks in. The value of 50.2Hz will work with a broader range of PV inverters/ |
+ | More information on adding Assistants is [[assistants: | ||
+ | ====== 2. GX Devices & Fronius PV Inverters ====== | ||
+ | By connecting a Fronius PV Inverter and GX device (eg [[https:// | ||
+ | This document describes how to setup the monitoring functions. | ||
+ | ===== 2.1 Requirements ===== | ||
+ | 5. Configure the // | ||
+ | 7. Done! | ||
+ | ^ State ^ Meaning ^ | ||
+ | ====== 3. Frequently Asked Questions ====== | ||
+ | ==== Q1 Why doesn' | ||
+ | See [[: | ||
+ | ==== Q6 What do I do if my Fronius PV-inverter is detected as Unknown PV-inverter and cannot be configured as 3-phase? ==== | ||
+ | Later Fronius PV-inverters support both the Fronius SolarAPI- as well as the industry standard SunSpec protocol. When SunSpec is not available the GX device cannot properly detect the properties of the PV-inverter unless it is one of a fixed list of known older models. Newer PV-inverters will then show up as Unknown, and you will not be able to configure them as 3-phase. | ||
+ | The solution is to configure SunSpec support on the PV-inverter. | ||
+ | * Log into the Fronius web interface. | ||
+ | * Go to the Modbus tab | ||
+ | * Set Data export via Modbus to tcp. | ||
+ | * set Sunspec Model Type to int + SF | ||
