ac_coupling:fronius
ac_coupling:fronius [2015-12-03 15:15] – [Setting up the Victron Multi or Quattro] mvader | ac_coupling:fronius [2020-03-19 15:37] – guy_stewart | ||
- | ===== Frequency shifting ===== | + | {{: |
+ | For Fronius information on the same subject, see their [[http:// | ||
+ | {{youtube> | ||
- | This is a very easy setup. The Fronius Setup MG has been developed in close cooperation with Victron | + | This is a very easy setup. The Fronius Setup Microgrid |
- | * Fronius | + | |
- | Recommended for new systems | + | For new systems the Fronius |
- | When the PV modules need to be grounded, | + | The use of Fronius Galvo inverters |
- | When setting | + | **Compatible UL inverters** (for "US type AC grid") are: |
+ | * Fronius | ||
- | ===== Setting up the Fronius with MG 50/60 ===== | + | For the UL inverters, some more Microgrid Setups are available (e.g. for connection with Neutral conductor or without). Also the UL inverters can be used in 60Hz as well as in 50Hz applications. More information can be found in the user manuals. |
+ | When setting up a system, always update both the Fronius and the Victron devices to their latest firmware versions. For the latest Fronius firmware and information how to update use this link: | ||
+ | [[http:// | ||
+ | ===== 1.3 Setting up the Fronius with Setup MG50/MG60 ===== | ||
Line 39: | Line 56: | ||
- Note that it is not necessary to change the default settings in the Assistant. \\ {{: | - Note that it is not necessary to change the default settings in the Assistant. \\ {{: | ||
Line 51: | Line 67: | ||
- | More information on adding Assistans is [[assistants: | + | Table for settings for 50Hz and 60Hz frequency |
- | ===== Frequently asked questions ===== | + | | ** State ** | ** 50Hz ** | ** 60Hz ** |. | |
+ | | Start| 51.0 | 60.2|Hz| | ||
- | === Why doesn' | + | More information on adding Assistants is [[assistants: |
+ | ====== 2. GX Devices & Fronius PV Inverters ====== | ||
+ | By connecting a Fronius PV Inverter and GX device (eg [[https:// | ||
+ | This document describes how to setup the monitoring functions. | ||
+ | ===== 2.1 Requirements ===== | ||
+ | 5. Configure the // | ||
+ | 7. Done! | ||
+ | ^ State ^ Meaning ^ | ||
+ | ====== 3. Frequently Asked Questions ====== | ||
+ | ==== Q1 Why doesn' | ||
+ | See [[: | ||
